Update all views in a sheet to turn on Associative check box
GeorgK
Advisor Advisor
Message 1 of 34
GeorgK
Hello together,
is there a solution to turn on associative check box in a drawing? How to get the ActiveDesignViewRepresentation name?
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oDrawView As DrawingView
For Each oSheet In oDrawDoc.Sheets For Each oDrawView In oSheet.DrawingViews Representation = oDrawView.ActiveDesignViewRepresentation If Representation <> "" Then ' How to get the name 'oDrawView.SetDesignViewRepresentation(Representation, True) End If Next Next
 Thank you
Georg
Replies (33)
Message 21 of 34
steveh5
Both lines appear to be erroring... I attempted to delete both either/or...
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
Message 22 of 34
steveh5
Now this...
Steve Hilvers
Message 23 of 34
NachoShaw
The nuances of VBA. you need to change the 'Set' to 'Call'. You're not setting anything, you're calling the function with parameters
Call oDrawView.SetDesignViewRepresentation("Default", True)
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 24 of 34
NachoShaw
your code should be
Dim app As Application: Set app = ThisApplication
Dim oDrawDoc As DrawingDocument: Set oDrawDoc = app.ActiveDocument
Dim oSheet As Sheet
            If oDrawView.ReferencedDocumentDescriptor.ReferencedDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            End If
        Next
Next
Nacho
Message 25 of 34
steveh5
Thanks.
I see what the this code is doing now.
It's almost what we looking for.
So, it does check the box for Associative, but I don't want it to change the View Rep.
Can it read the view rep and then toggle it?
Steve Hilvers
Message 26 of 34
NachoShaw
Ok. This will get the name of the current view rep in the view then set the association to true using the SetDesignViewRepresentation function
Dim oSheet As Sheet
                Dim name As String: name = oDrawView.DesignViewRepresentation
                Call oDrawView.SetDesignViewRepresentation(name, True)
            End If
        Next
Next
you could also add a condition to check the current viewrep and update it to what you need if it was incorrect
Dim oSheet As Sheet
                If Not name = "Default" Then
                name = "Default"
                End If
            End If
        Next
Next
Nacho
Message 27 of 34
NachoShaw
and finally, if you need to toggle the associative on / off (which is the definition of toggle), you can toggle it like this
Dim oSheet As Sheet
                name = "Default"
                End If
                Dim Assoc As Boolean: Assoc = oDrawView.DesignViewAssociative
                Call oDrawView.SetDesignViewRepresentation(name, Not Assoc)
            End If
        Next
Next
Nacho
Message 28 of 34
steveh5
That's it...seems to be working!!!
If we want to add in views that are .iams or .ipn's
possible to put an OR in the statement....
If so...what's the syntax for .ipn's here?
Steve Hilvers
Message 29 of 34
NachoShaw
Hi
I would do a Select Case
Select Case oDrawView.ReferencedDocumentDescriptor.ReferencedDocumentType
   Case DocumentTypeEnum.kAssemblyDocumentObject
   'assembly code here
   Case DocumentTypeEnum.kPresentationDocumentObject
   'presentation code here
   Case DocumentTypeEnum.kPartDocumentObject
   'part code here
End Select
Nacho
Message 30 of 34
steveh5
Having problem with the Views that are referring to an .ipn.
Statement works fine as a "kAssemblyDocumentObject"
But, when I change it to a kPresentationDocumentObject
It bugs out...
Best,
Steve Hilvers
Message 31 of 34
NachoShaw
Hey
Good news & bad news...
Good News
you can change the associative type like this
oDrawView.PresentationViewAssociative = True
Bad News
Presentation views are different to part & assembly views as in, they dont directly show the view rep but instead, show the list of snapshot views in the presentation file. If you need to change the view rep, the underlying file would need to be opened and the view rep change at file level in the snapshop view.
Heres the bad news; there is a function in a DrawingView that is supposed to get the name of the current snapshot view in the drawingview which you would need to correct update the viedwrep of the snapshot in the presentation file however, its been flagged as bug and is currently not working. I found a thread from about 3 yrs ago explaining this so im assuming its yet another one of those things autodesk doesnt care about.
to get around it, you will need the name of the view so that you can -
open the underlying presentation file
  1. edit the snapshot
  2. change the viewrep
  3. save and close it
  4. update the drawing sheet
  5. associate the view
thanks
Nacho
Message 32 of 34
steveh5
@NachoShaw
Thanks for all the help!!!
Finally got it working.
It toggles on "Associative" for all views in an .idw's that refer to an .iam or .ipn
Ignores ipt views.
Combined it with an iLogic script that runs the VBA before it saves.
Best,
Steve Hilvers
Message 33 of 34
NachoShaw
great news.
why dont you combine all of the VBA witrh iLogic, seems pointless using both and iLogic supersedes VBA
Nacho
Message 34 of 34
steveh5
Just using the iLogic to trigger the VBA to run on only idw's.
Before a save, a trigger runs the iLogic which tells the VBA to run.
'This runs the VBA to check the Associative box on all Assembly views
	InventorVb.RunMacro("ApplicationProject", "Module3", "ViewAssoc3")
Possible to do this otherwise?
Steve Hilvers
