Unspecified Error
Unspecified Error
birju.work99
Observer Observer
Unspecified Error
birju.work99
Observer
Observer
Hello Everyone,
I am trying to update my model using ilogic for length (Its the input)  1000 to 3000 mm (100 mm intervals)
Model has hole patterns and centre holes.
What I want is first check all holes are unsuppressed (For which I used For loop)
Then,
For lengths 1100,1300,1500 etc  = suppress cetre holes
For lengths 1000,1200,1400 etc = Move centre holes 50 mm further and suppress next occurrence of centre holes
Please check the model , youl will understand.
It keeps giving me unspecified error on line 11. When I open the VBA , indent the lines. It works for that length, if I chenge the length error appears again.
Thanks in advance.
dalton98
What's happening is your parameter has updated but your model hasn't. Add this at the start of your rule:
ThisDoc.Document.Update
Andrii_Humeniuk
Hi @birju.work99 . Please try this code:
Dim oDoc As PartDocument = ThisDoc.Document
oDoc.Update()
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oUsParams As UserParameters = oDef.Parameters.UserParameters
Dim dInstances As Double = oUsParams("Instances").Value
Dim oPatterns As RectangularPatternFeatures
oPatterns = oDef.Features.RectangularPatternFeatures
Dim oPattern1, oPattern2 As RectangularPatternFeature
oPattern1 = oPatterns("Rectangular Pattern5")
oPattern2 = oPatterns("Rectangular Pattern6")
Dim oElements1, oElements2 As FeaturePatternElements
oElements1 = oPattern1.PatternElements
oElements2 = oPattern2.PatternElements
For i As Integer = 2 To dInstances
	oElements1(i).Suppressed = False
	oElements2(i).Suppressed = False
Next
oElements2(dInstances).Suppressed = True
If Length Mod 200 = 0 Then
	oElements1((dInstances / 2) + 1).Suppressed = True
	CentreOffset_1 = 50 mm
Else
	oElements1(Ceil(dInstances / 2)).Suppressed = True
	CentreOffset_1 = 0 mm
End If
oDoc.Update()
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
birju.work99
Observer
Observer
It stops the error but model is not updating.
Andrii_Humeniuk
Add to the end of the code before updating the document Rebuild the document.
oDoc.Rebuild()
oDoc.Update()
birju.work99
Observer
Observer
Thanks Andrii. It works perfectly.
Can you please me understand what have you done ?
It looks like you define each patterns and parameters, but is this necessary every time ?
