Unspecified Error-possibly tied to BOM table
Message 1 of 8
in one of my template files, I ran into this problem.
this message shows up when I created a custom LOD and a user true/false parameter in the assembly file, and a BOM table
is inserted into the idw file.
anyone ran into this issue? how do I get it resolved?
Replies (7)
Message 2 of 8
Owner2229
Hi, can you post a screenshot of the "More Info" tab from the error? And also the rule "Transfer", so we can dig up the problem.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 8
see screenshots below:
here are the screenshots from the assembly file, the LOD and parameter are for turning on and off the part "Conduit_0".
Parameter:
LOD screenshot and the rule screenshot(in assembly):
Message 4 of 8
here are the screenshots from idw:
Message 5 of 8
here are sreenshots from assembly file:
parameter:
LOD:
Rule:
Message 6 of 8
Owner2229
The problem is in the last line. It's failing to run the rule in the assembly file.
My guess would be you don't have the assembly file ("POLE BASE.idw") currently open, right?
Anyway, why are you running the rule in the assembly?
Mike
Message 7 of 8
I do have the assembly file open when I tried to test it.
I am kinda new to Inventor ilogic, I didnt know the best way to approach this problem.
well, the goal is to be able to have users input info in idw, and depending on the input, certain conduits will disappear
in all the views.
is there a better/more efficient way to solve this?
Message 8 of 8
anyone?
