Ilogic Sheet metal
Ilogic Sheet metal
Ilogic Sheet metal
Hi
I do occasionally work sheetmetal parts, here I could use a Ilogic function to cut at a bend (do not know the correct english term for this)  , where a hole is placed near to a bend.
Maybe there are some who have already made it, or have an idea for this
Rob67ert
You could use an iFeature for that.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
CCarreiras
Create those features always with "Cut across bend" active.
CCarreiras
You could unfold it, cut it, then refold it.
I'm not familiar with ifeature,  how does it Work?
