Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Dear Friends,
when i try to set dimensionStyle "AlternateDisplayUnitType"property , sometimes it works fine and some times it gives "Unspecified Error"
Please let me know what is the problem with my code
Inventor.DimensionStyle oDimStyle = m_inventorDrawingDoc.StylesManager.DimensionStyles[3];
for (int ii = 1; ii <= s1.Count; ii++)
DrawingCurve s2 = s1[ii];
if (s2.CurveType == CurveTypeEnum.kLineSegmentCurve)
GeometryIntent top1 = oSheet.CreateGeometryIntent(s2, null);
Inventor.Layer oDimLayer = m_inventorDrawingDoc.StylesManager.Layers[21];
oSheet.DrawingDimensions.GeneralDimensions.AddLinear(endPoint1, top1, null,
DimensionTypeEnum.kVerticalDimensionType,
true, oDimStyle, oDimLayer);
oDimStyle.AlternateDisplayUnitType = false;
oDimStyle.LinearUnits = UnitsTypeEnum.kMillimeterLengthUnits;
Thanks & Regards,
Satyajeet
Hi Satyajeet,
When you get "Unspecified Error", it's because the
style used is a Library one , you need to convert it to Local before reseting
its properties.
Pleaser refer my VB code for converting to Local
style:
Sub test()
    Dim oDrawDoc As DrawingDocument
    Set
oDrawDoc = ThisApplication.ActiveDocument
    Dim oStyle As DimensionStyle
    Set
oStyle = oDrawDoc.StylesManager.DimensionStyles(3)
    If oStyle.StyleLocation = kLibraryStyleLocation
Then
        Set oStyle =
oStyle.ConvertToLocal
    End If
    If oStyle.AlternateUnitsDisplay = True
Then
oStyle.AlternateDisplayUnitType = False
    End
If
End Sub
-Lisa
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Dear
Friends,
code
& Regards,
Satyajeet
Thanks Lisa for solving my crash problem.
I implement following code in my code. Now it is working fine.
if (oDimStyle.StyleLocation == StyleLocationEnum.kLibraryStyleLocation)
oDimStyle = (Inventor.DimensionStyle )oDimStyle.ConvertToLocal();
if (oDimStyle.AlternateDisplayUnitType == true)
if (oDimStyle.LinearUnits != UnitsTypeEnum.kMillimeterLengthUnits)
Satyajeet
GCvanLan
I'm getting the same error:
    Edit Rule
    Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL)),
Except that I'm not trying to adjust the style libraries at all.  Here's my code:
'Shunting values to custom properties
iProperties.Value("Custom", "ProjectNumber") = ProjectNumber
iProperties.Value("Custom", "ProjectName") = ProjectName
iProperties.Value("Custom", "ProjectLocation") = ProjectLocation
iProperties.Value("Custom", "ContName") = ContName
iProperties.Value("Custom", "ContLocation") = ContLocation
iProperties.Value("Custom", "EngName") = EngName
iProperties.Value("Custom", "EngLocation") = EngLocation
iProperties.Value("Custom", "CustPONum") = CustPONum
iProperties.Value("Custom", "Model") = Model
' Passing Varibles to D101 Assy
Parameter("101 General Assembly - Mounting Bars", "ProjectNumber") = ProjectNumber
Parameter("101 General Assembly - Mounting Bars", "ProjectName") = ProjectName
Parameter("101 General Assembly - Mounting Bars", "ProjectLocation") = ProjectLocation
Parameter("101 General Assembly - Mounting Bars", "ContName") = ContName
Parameter("101 General Assembly - Mounting Bars", "ContLocation") = ContLocation
Parameter("101 General Assembly - Mounting Bars", "EngName") = EngName
Parameter("101 General Assembly - Mounting Bars", "EngLocation") = EngLocation
Parameter("101 General Assembly - Mounting Bars", "CustPONum") = CustPONum
Parameter("101 General Assembly - Mounting Bars", "Model") = Model
Parameter("101 General Assembly - Mounting Bars", "Reducer") = Reducer
Parameter("101 General Assembly - Mounting Bars", "ReducerMake") = ReducerMake
' Passing Varibles to D101 Assy Jackstud Layout
Parameter("101 Jackstud layout - Mounting Bars", "ProjectNumber") = ProjectNumber
' Passing Varibles to D103 Assy
Parameter("103 Dual-Gate", "ProjectNumber") = ProjectNumber
Parameter("103 Dual-Gate", "ProjectName") = ProjectName
Parameter("103 Dual-Gate", "ProjectLocation") = ProjectLocation
Parameter("103 Dual-Gate", "ContName") = ContName
Parameter("103 Dual-Gate", "ContLocation") = ContLocation
Parameter("103 Dual-Gate", "EngName") = EngName
Parameter("103 Dual-Gate", "EngLocation") = EngLocation
Parameter("103 Dual-Gate", "CustPONum") = CustPONum
Parameter("103 Dual-Gate", "Model") = Model
iLogicVb.UpdateWhenDone = True
