Unspecifed error in AddLinear
Hi friends,
I have implement following code(C#) to add linear dimension.But after execution, "Unspecifed error " message occured at AddLinear API. Can you please tell me what is the problem with code.
Point2d stPoint1 = m_inventorApp.TransientGeometry.CreatePoint2d(45.6113, 16.015);
Point2d endPoint1 = m_inventorApp.TransientGeometry.CreatePoint2d(45.6113, 18.515);
GeometryIntent top1 = oSheet.CreateGeometryIntent(endPoint1, PointIntentEnum.kEndPointIntent);
GeometryIntent bottom1 = oSheet.CreateGeometryIntent(stPoint1, PointIntentEnum.kStartPointIntent);
Inventor.DimensionStyle oDimStyle = m_inventorDrawingDoc.StylesManager.DimensionStyles[3];
Inventor.Layer oDimLayer = m_inventorDrawingDoc.StylesManager.Layers[21];
oSheet.DrawingDimensions.GeneralDimensions.AddLinear(endPoint1, top1, bottom1, DimensionTypeEnum.kVerticalDimensionType, true, oDimStyle, oDimLayer);
Thanks in Advance
Satyajeet
Hi Satyajeet,
You shouldn't create the GeometryIntent using the
Point2d object as Geometry parameter. Valid input can be DrawingCurve.
-Lisa
Hi
friends,
Point2d stPoint1 =
Point2d
18.515);
oDimLayer);
Thanks in
Advance
Satyajeet
Hi Lisa,
Thanks for fast reply.
But how should i take curve from "Drawing View" ?
Thanks & Regards,
Satyajeet
I got the answer.
By following code, i will get drawingcurves from which i need find out my curves.
DrawingCurvesEnumerator s1 = (DrawingCurvesEnumerator)oBaseView.get_DrawingCurves(null);
Satyajeet
C-Hoppen
You just made my day. Smiley Very Happy I was wondering about get_DrawingCurves(Object ModelObject). It's c# related and not documented.
