Units keep changing when using iLogic
JBEDsol
JBEDsol
I'm trying to create a rule that updates the weight of a Content Center pipe as the length changes.
Few explanations.
So the CC part uses L and PL (not sure why both but I just copied the existing to make sure it works smooth with Tube & Pipe).  I'm not updating the custom iProperty via the Family Table because it only works for Standard CC Parts.  I'm using a custom iProperty rather than a parameter because that's how everything else reads.  It was setup a long time ago and I'm working w/ what we have established.
When I want to input a Custom CC part PL is in ft, L is in inches.  The part's document settings are in inches.  The family table for "L" and "PL" both have units set to feet.  So I set everything to ft and put the following iLogic rule.
iProperties.Value("Custom","WEIGHT TOTAL")=PL*iProperties.Value("Custom","WEIGHT UNIT")
However the part keeps changing L to inches.  And the Rule seems almost arbitrarily multiplying by feet sometimes and Inches others.  I've no clue what's going on or how to fix it.  When I replace the family template the document settings won't update.  I get no consistency.  Sometimes the value will be 504 and others 2.3.  All depending on whether it want to read inches or feet.
JoãoASilva
@JBEDsol ,
Have you tried changing the document settings on your templates to the desired dimension type, create a new file and test on that new file?
João Silva
Mechanical Engineer
A.Acheson
@JBEDsol
I see the same behaviour in a Pipe family  I was setting up, but no ilogic being used. Change PL and L to ft in family table. When placed PL gets ft and L gets in. I will test again to see what I can figure out. It might be a T&P pipe phenomena? Did you have any resolution to this?
Regards
Alan
bradeneuropeArthur
@JoãoASilva wrote:
@JBEDsol ,
Have you changed this?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
A.Acheson
@JBEDsol
A template file replace didn't help. The user parameter L retains the in units. They must  have been hardcoded.
Two methods work to retain the user parameter units.
Method 1
Change user parameter L to L_1 or whatever you like in a custom part, perform a template file replace and map template parameter L to L_1. effectively recreating the user parameter.  See attached photos
Method 2
Republish  the family with units changed in the user parameter allowed the units to be retained. Downside all the extra work and perhaps having to replace the file wherever used.
Regards
Alan
bradeneuropeArthur
What template file have you replaced? From the Content Center Family?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
