Unable to create OriginIndicator on a workpoint.
Message 1 of 9
Hi Experts,
Inventor 2017.4.5
Language: C# or VBA
I am attempting to create a OriginIndicator in DrawingView and would like to use a WorkPoint as reference.
This works fine in the UI and throws an exception using the API. All possible permutations and combinations has been attempted. Here is a simple sample VBA code and instructions:
1. Create a drawing document.
2. Place a base view of a part file.
3. Include any workpoint from the model.
Now run this macro:
Dim dwg As DrawingDocument
Set dwg = ThisDocument
Dim view As DrawingView
Set view = dwg.ActiveSheet.DrawingViews(1)
Dim cm As Centermark
Set cm = dwg.ActiveSheet.Centermarks(1)
Dim geomInt As GeometryIntent
Set geomInt = dwg.ActiveSheet.CreateGeometryIntent(cm)
view.CreateOriginIndicator geomInt
Cheers,
-Thilak Rao
Replies (8)
Message 2 of 9
frederic.vandenplas
hi @Anonymous
This should work (vba)
Sub CreateOrigin()
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
Dim oView As DrawingView
Set oView = oSheet.DrawingViews(1)
Dim oCm As Centermark
Set oCm = oSheet.Centermarks(1)
Dim oGI As GeometryIntent
Set oGI = oCm.AttachedEntity
Call oView.CreateOriginIndicator(oGI)
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 3 of 9
Hi Frederic,
Did you at least execute this code and see it work? Or are you assuming that it should work.
Because clearly there is a type mismatch at:
and I do not see any line of code that does "creategeometryintent".
-Thilak Rao
Message 4 of 9
frederic.vandenplas
Hi @Anonymous ,
I've created the macro, created a baseview, placed a sketchpoint on the center of this arc, and ran the code
attachedentity is oGI is actually GeometryIntent, so i only have to refer, not create it.
Message 5 of 9
frederic.vandenplas
Correction, placed a centerpoint instead of "placed a sketchpoint"
Message 6 of 9
Hi Frederic,
Appreciate your willingness to help here but I haven't resolved this yet.
1. Created a drawing view.
2. Placed a center mark.
3. Executed your macro and still got an error as attached.
BTW, I am on Inventor Release 2017.4.5
-Thilak Rao
Message 7 of 9
chrisdrogers
Did you ever find a resolution to this?  I am finding the same error when using workpoints.
Message 8 of 9
Yes. They fixed it in Inventor 2019.
-Thilak Rao
Message 9 of 9
chrisdrogers
I upgraded to Inventor 2019 and it did not work, however I discovered that the fix is in 2019.2 and greater.
