Fastest way to check if Thumbnail contains any graphics
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I need to compose iLogic (or VB) code for as-fast-as-possible check whether active document's Thumbnail is empty (has at least two pixels different in color). I guess it is not Inventor's special task yet don't know where to start from.
AddReference "Stdole.dll"
Imports stdole
Sub Main
	Dim oThumb As stdole.IPictureDisp
	Dim NoThumb As Boolean=1
Try
	oThumb=ThisDoc.Document.Thumbnail
	NoThumb=0
	' if ??? Then MsgBox("Doc's Thumb is empty")
Catch
   MsgBox ("Active DOc has no Thumb")
End Try
End Sub
Maybe there is some VB method otherwise I will compare each and every pixel with white which is supposed to be too long. Any help is appreciated.
Please vote for Inventor-Idea Text Search within Option Names
Maxim-CADman77
I'm attaching two samples (one with meaningful and second with empty thumbnail)
chandra.shekar.g
Autodesk Support
Autodesk Support
@Maxim-CADman77,
Both parts are empty. Can you please re check it again? Also specify Inventor version.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Maxim-CADman77
Yes - 3Dgeometry of both are empty. But one has a thumbnail embedded. Other has an empty thumbnail (which btw could be embedded as well In context of the tsak it doesn't matter if it is natural or embedded).
Those are testing samples for the task.
I'm using Inventor 2014 but I don't mind to get solution for some newer version (I suppose It would be applicable for 2014 as well).
clutsa
So I'm cheating and making assumptions but, is it possible to think that if the part has no volume and the user didn't set the thumbnail to an imported image that the preview will be blank?
Imports stdole
Sub Main
	Dim doc As Document = ThisApplication.ActiveDocument
Try
	oThumb=doc.Thumbnail
	NoThumb=0
	If doc.ComponentDefinition.MassProperties.Volume = 0 Then
		If Not doc.ThumbnailSaveOption = THumbnailSaveOptionEnum.kImportFromFile Then
Catch
End Try
End Sub
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
philip1009
Document.Thumbnail() As IPictureDisp is a read only property whose value is an IPictureDisp.
IPictureDisp is a Microsoft object so you'll need to learn some Microsoft SDK:
https://msdn.microsoft.com/en-us/library/windows/desktop/ms680762(v=vs.85).aspx
My understanding is iLogic can't import objects like this, I may be wrong there, feel free to share your results with us.  Otherwise you'll have to make the code in Visual Studio and develop the code as an Inventor Add-In.
BrianEkins
Both of the part files you originally attached contain a thumbnail image.  It's just one of them is visually empty because the entire image is a single color.  It is possible for a document not to have any thumbnail image at all.  I've attached an example.  In this case, calling the Thumbnail property fails.
In your case, you are getting back images, so you'll need to check the contents of the image to see if all of the pixels are the same color.  The underlying system that the Inventor API is based on (COM Automation) uses the IPictureDisp object to represent images.  If you're using VBA then it's relatively easy to work with.  However, if you're using a .NET based language (iLogic uses VB.NET) they don't natively support IPictureDisp so you'll either have to import and use Win32 functions or convert the IPictureDisp to a .NET image or bitmap and then use functions they provide to examine the contents of the image in more detail.
Brian Ekins
