Can't create ClientFeature
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I've tried several samples devoted to creation ClientFeature and still can't create any one.
For example
https://forums.autodesk.com/t5/forums/postpage/board-id/120?interaction_style=forum&catId=70&boardId...
Gives me  "Compile error: Syntax error"
(I run Inventor, create IPT, open build-in VB Editor, create new module, paste the code and press Run).
What I'm missing?
Thanks in advance.
Please vote for Inventor-Idea Text Search within Option Names
chandra.shekar.g
Autodesk Support
Autodesk Support
@Maxim-CADman77,
Hoping that below VBA code would help to add client feature in a PartDocument.
Public Sub Main()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oClientFeatDef As ClientFeatureDefinition
    Set oClientFeatDef = oDef.Features.ClientFeatures.CreateDefinition()
    Dim oClientFeat As ClientFeature
    Set oClientFeat = oDef.Features.ClientFeatures.Add(oClientFeatDef, "MyNode")
    oClientFeat.Name = "Testing"
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
