Tweak Weight Calculation
TobFischer94
TobFischer94
Hello friends,
i have a question:
I have a part (see attached file) which is construed from two extrusions.
I have to set those extrusions to separate volume bodies, but i would like to calculate the weight of the part (which Inventor creates in the iproperties --> physical properties), as if those seperate volume bodies were not separate, but instead merged together.
For example:
The volume body created by Extrusion1 weighs 1,3 kg
The volume body created by Extrusion2 weighs 4,3 kg
Now, if i look at the physical iproperties for the multi-body part, i see a weight of about 5,6 kilograms.
But this is (in my case) false, since the intersecting volumes are calculated twice.
Instead of this weight, i would like to see (or calculate, if needed, with iLogic), a weight of 4,9 kilograms, which you get when you merge these two volume bodies.
Help would be very appreciated
Many thanks
Ralf_Krieg
Hello
Why not use combine command?
- select body1 as base body
- select body 2 as tool body
- select cut option
- activate "keep tool body" option
- make body 2 visible again after command finished
No tewak, just standard functionality.
R. Krieg
RKW Solutions
www.rkw-solutions.com
TobFischer94
yes, it works.
Thank you very much!
