iLogic - Selection of workpoints for CSV export
r.claus
Message 1 of 18
r.claus
Hi everyone, I would be very grateful for your help. I was able to create the below rule for exporting workpoints.
  1. However, now I would like to export only certain group of workpoints created with a certain feature, for example "Rectangular Pattern Workpoints1". It should also be noted that the number of workpoints is always different, because we are working with a dynamic model. Therefore, the names of the workpoints cannot be used to differentiate between them. It would also be conceivable to set workpoints within a feature to invisible to be able to differentiate which workpoints are exported. Also, other possibilities for the selection of the workpoints, e.g., folders, can be suggested.
  1. Besides, the CSV file should always have the same size. So e.g., 100 columns, even if there are only 60 workpoints. Is this possible? The blanks can then be filled with a given value, e.g., "f".
Thank you very much for your support.
'Export Workpoints
Dim oDoc = ThisDoc.Document
Dim partDoc = ThisApplication.ActiveDocument
Dim partDef = partDoc.ComponentDefinition
Dim dlmtr As String = ";" 'or vbTab
Dim filePath As String
Dim fileName As String
Dim i As Integer
filePath = ThisDoc.Path & "\"
fileName = "CSV Name" & " " & Number & ".csv"
expFile = System.IO.File.CreateText(filePath + fileName)
		expFile.Write("Name" & dlmtr)
For i = 1 To partDef.WorkPoints.Count
	If partDef.WorkPoints.Item(i).Visible = True
	expFile.Write(partDef.WorkPoints.Item(i).Name & dlmtr)
		Else expFile.Write("f" & dlmtr)
Next
		expFile.Write("Number" & dlmtr)
		expFile.Write("Customer" & dlmtr)
		expFile.Write("Type" & dlmtr)
	expFile.Write(vbCrLf & "X" & dlmtr)
	If partDef.WorkPoints.Item(i).Visible = True Then
	expFile.Write(Round(partDef.WorkPoints.Item(i).Point.X * 10,1) & dlmtr)
Next
		expFile.Write(Number & dlmtr)
		expFile.Write(Customer & dlmtr)
		expFile.Write(Type & dlmtr)
	expFile.Write(vbCrLf & "Y" & dlmtr)
	expFile.Write(Round(partDef.WorkPoints.Item(i).Point.Y * 10 -5,1) & dlmtr)
Next
	expFile.Write(vbCrLf & "Z" & dlmtr)
	expFile.Write(Round(partDef.WorkPoints.Item(i).Point.Z * 10 -100,1) & dlmtr)
Next
expFile.Close
ThisDoc.Launch(filePath + fileName)
Replies (17)
Message 2 of 18
Ralf_Krieg
Hello
Folders are until now not available in parts. So this option is not possible. Make all workpoints invisible that shall not be exported is possible, if you select nothing. Then all visible workpoints will be exported. In addition to the visibility, origins of (user) coordinate systems are excluded too.
If you select one or more workpoints or one or more patterns with workpoints or a combination of workpoints and patterns, it should export the selected points.
The file has always 100 columns now.
Maybe I missed some constellations.
Option Explicit on
Class ThisRule
	Private GetPoints As ObjectCollection
	Private Sub Main
	Dim oDoc As PartDocument = ThisApplication.ActiveDocument
	Dim oSelSet As SelectSet = oDoc.SelectSet
	If oSelSet.Count = 0 Then
	    If MsgBox ("Nothing selected, export all Workpoints?",MsgBoxStyle.YesNo ,"iLogic Export selected Workpoints to CSV") = vbNo Then
	    	Exit Sub
		Else
			Dim oWP As WorkPoint
			For Each oWP In oDoc.ComponentDefinition.WorkPoints
				oSelSet.Select(oWP)
			Next
	GetPoints = ThisApplication.TransientObjects.CreateObjectCollection
	Dim oSel As Object
	For Each oSel In oSelSet
	    Select Case oSel.Type
	        Case kRectangularPatternFeatureObject:
	            Call GetPointsRect(oSel)
	        Case kCircularPatternFeatureObject:
	            Call GetPointsCirc(oSel)
	        Case kWorkPointObject:
	            If oSel.Visible = True Then
	                If oSel.IsCoordinateSystemElement = False Then
	                    Call GetPoints.Add(oSel)
	        Case kBrowserFolderObject:  ' Nope, no folders in parts
	    End Select
	Next
	ExportWorkpoints(GetPoints)
	End Sub
	Private Sub GetPointsRect(ByVal oPatternFeature As RectangularPatternFeature)
	    Dim i As Integer
	    Dim j As Integer
	    Dim oParentFeatures As ObjectCollection= oPatternFeature.ParentFeatures
	    For i = 1 To oParentFeatures.Count
	        If TypeOf oParentFeatures(i) Is WorkPoint Then
	            If oParentFeatures(i).Visible = True Then
	                If oParentFeatures(i).IsCoordinateSystemElement = False Then
	                    Call GetPoints.Add(oParentFeatures(i))
	        ElseIf TypeOf oParentFeatures(i) Is RectangularPatternFeature Then
	            If oParentFeatures(i).Suppressed = False Then
	                Call GetPointsRect(oParentFeatures(i))
	        ElseIf TypeOf oParentFeatures(i) Is CircularPatternFeature Then
	                Call GetPointsCirc(oParentFeatures(i))
	    Next
	    Dim oPatternElements As FeaturePatternElements= oPatternFeature.PatternElements
	    For i = 1 To oPatternElements.Count
	        Dim oResultFeatures As ObjectCollection = oPatternElements(i).ResultFeatures
	        If Not oResultFeatures Is Nothing Then
	            For j = 1 To oResultFeatures.Count
	                If TypeOf oResultFeatures(j) Is WorkPoint Then
	                    If oResultFeatures(j).Visible = True Then
	                        If oResultFeatures(j).IsCoordinateSystemElement = False Then
	                            Call GetPoints.Add(oResultFeatures(j))
	            Next
	    Next
	End Sub
	Private Sub GetPointsCirc(ByVal oPatternFeature As CircularPatternFeature)
	    Dim i As Integer
	    Dim j As Integer
	    Dim oParentFeatures As ObjectCollection = oPatternFeature.ParentFeatures
	    Next
	    Dim oPatternElements As FeaturePatternElements = oPatternFeature.PatternElements
	            Next
	    Next
	End Sub
	Private Sub ExportWorkpoints(ByVal oWorkPointColl As ObjectCollection)
		Dim i As Integer
		Dim j As Integer
		Dim expfile As System.IO.StreamWriter = System.IO.File.CreateText(filePath + fileName)
		Dim aFileData(3, 100) As String
		afiledata(0, 0) = "Name"
		afiledata(1, 0) = "X"
		afiledata(2, 0) = "Y"
		afiledata(3, 0) = "Z"
		For i = 1 To 100
			Try
				afiledata(0, i) = oWorkPointColl(i).Name
				afiledata(1, i) = Round(oWorkPointColl(i).Point.X * 10, 1)
				afiledata(2, i) = Round(oWorkPointColl(i).Point.Y * 10, 1)
				afiledata(3, i) = Round(oWorkPointColl(i).Point.Z * 10, 1)
			Catch
				afiledata(0, i) = "f"
				afiledata(1, i) = "f"
				afiledata(2, i) = "f"
				afiledata(3, i) = "f"
			End Try
		Next
		expfile.Write("Number" & dlmtr & Number & vbCrLf)
		expfile.Write("Customer" & dlmtr & Customer & vbCrLf)
		expfile.Write("Type" & dlmtr & Type & vbCrLf)
		For i = 0 To 3
			For j = 0 To 100
				expfile.Write(afiledata(i,j) & dlmtr)
			Next
				expfile.Write(vbCrLf)
		Next
		expfile.Close
	End Sub
End Class
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 3 of 18
r.claus
Thank you very much for your help. Your code works very well.
Sorry, but I forgotten some information’s. It would be important that the workpoints do not always have to be selected manually. Is it possible to select certain patterns, e.g., pattern "Workpoints1" and pattern "Workpoints2" (and others) in the code? Besides the patterns, there are also some single workpoints to export. As an example: Workpoint_Head_1, Workpoint_Head_2, Workpoint_Head_3, Workpoint_Head_4 (and others). However, these have a fixed name and should line up behind the workpoints from the patterns.
Can the values "Number", "Customer" and "Type" also be set in the same row as the workpoints? Gladly at the beginning of the CSV file. In the first row the name and in the second the value.
Furthermore, the CSV must have a constant size and the blanks must be filled with "f".
Thanks again for your help. You really help me.
Message 4 of 18
r.claus
Message 5 of 18
Ralf_Krieg
Hello
You can create a multivalue fx-parameter named "WP_Export" and fill in the names of the workpoints and patterns. Or you comment out this line of code and use the hardcoded list above. As an alternative way, you can also select some workpoints/patterns and run the rule. Maybe this is useful for one time exports to avoid editing the standard list.
I've resorted Number, Customer and Type. Can you prove it is correct? Otherwise, can you sort the cells a needed in the CSV file and post a screenshot?
The CSV file always contains 100 columns for workpoint data. Empty columns will be filled with "f".
Option Explicit on
Class ThisRule
	Private Sub Main
	' define the patternfeatures and/or workpoints here, use the name from model browser
'	Dim Features As New List(Of String) From { _
'	"WorkPoints1", _
'	"WorkPoints4", _
'	"Workpoint_Head_1", _
'	"Workpoint_Head_2", _
'	"Workpoint_Head_3", _
'	"Workpoint_Head_4" _
	' or define the patternfeatures and/or workpoints as a multivalue fx-parameter "WP_Export"
	' use the name from model browser
	Dim Features = MultiValue.List("WP_Export").Cast(Of String)().ToList()
		' use the predefined list of named workpoints and features with workpoints
		' compare every rectangularpatternfeature, circularpatternfeature and workpoint
		' with all names Of the given list, if match add to selectset, remove mtached
		' item from list To shorten Next search
		Dim oRPF As RectangularPatternFeature
		Dim oCPF As CircularPatternFeature
		For Each oRPF In oDoc.ComponentDefinition.Features.RectangularPatternFeatures
			If Features.Find(Function(x) x.ToUpper = oRPF.Name.ToUpper) IsNot Nothing Then
				oSelSet.Select(oRPF)
				Features.Remove(Features.Find(Function(x) x.ToUpper = oRPF.Name.ToUpper))
		Next
		For Each oCPF In oDoc.ComponentDefinition.Features.CircularPatternFeatures
			If Features.Find(Function(x) x.ToUpper = oCPF.Name.ToUpper) IsNot Nothing Then
				oSelSet.Select(oCPF)
				Features.Remove(Features.Find(Function(x) x.ToUpper = oCPF.Name.ToUpper))
		Next
			If Features.Find(Function(x) x.ToUpper = oWP.Name.ToUpper) IsNot Nothing Then
				oSelSet.Select(oWP)
				Features.Remove(Features.Find(Function(x) x.ToUpper = oWP.Name.ToUpper))
		Next
		' Features should now be empty
		If Features.Count>0 Then
			MsgBox("Features NOT empty.", MsgBoxStyle.Critical, "iLogic ExportWorkPoints")
			For Each item As String In Features
				Logger.Debug(item)
			Next
	Dim oSel As Object
	    End Select
	Next
	oSelSet.Clear
	End Sub
	    Dim i As Integer
	    Dim j As Integer
	    Next
	            Next
	    Next
	End Sub
	    Dim i As Integer
	    Dim j As Integer
	    Next
	            Next
	    Next
	End Sub
		Dim i As Integer
		Dim j As Integer
		fileName = "CSV Name" & " " & ".csv"
		Dim aFileData(3, 103) As String
		afiledata(0, 0) = "Number"
		afiledata(1, 0) = Number
		afiledata(0, 1) = "Customer"
		afiledata(1, 1) = Customer
		afiledata(0, 2) = "Type"
		afiledata(1, 2) = Type
		afiledata(0, 3) = "Name"
		afiledata(1, 3) = "X"
		afiledata(2, 3) = "Y"
		afiledata(3, 3) = "Z"
		For i = 4 To 103
			Try
				afiledata(0, i) = oWorkPointColl(i-3).Name
				afiledata(1, i) = Round(oWorkPointColl(i-3).Point.X * 10, 1)
				afiledata(2, i) = Round(oWorkPointColl(i-3).Point.Y * 10, 1)
				afiledata(3, i) = Round(oWorkPointColl(i-3).Point.Z * 10, 1)
			Catch
			End Try
		Next
		For i = 0 To 3
			For j = 0 To 103
			Next
		Next
		expfile.Close
	End Sub
End Class
R. Krieg
RKW Solutions
Message 6 of 18
r.claus
Thank you very much for your help. I am very grateful to you for that.
Your code works perfectly and also provides very good selection options. Great work.
The sorting of the cells is also correct.
Really super nice of you.
Message 7 of 18
r.claus
unfortunately the requirements have changed a bit and I need your help again.
For a better overview I have attached a CSV file how the result should look like.
The individual workpoints and the patterns are to be exported one after the other at fixed positions. An assignment of the positions (i,j) of the individual workpoints and patterns should be possible. In addition, the workpoints in the pattern are to be numbered consecutively and thus have fixed names. The patterns have a maximum but different number of points. The number should be adjustable (in the code).
As an example:
4 to 20 single workpoints with selectable names
20 points in pattern 1
10 points in pattern 2
90 points in pattern 3
Important: If the selected workpoints (multivalue fx-parameter) are not visible or the value is empty, there should be an "f" instead of the value (X, Y, Z). So the points (column) should not be removed and the csv file must still have a constant size.
Maybe work with "oWorkPointColl" for each group of workpoints to distinguish them?
I hope you can help me for one more time?
Thank you very much again
Message 8 of 18
Ralf_Krieg
Hello
I need to think about it a bit. I have some questions.
1. You said 4 to 20 single workpoints. If the output file should always had a constant count of columns, we must always take 20 and fill the empty places with "f", right?
2. Is it possible that a workpoint, selected as single workpoint for export, is also the base point of a rectangular pattern? If so, list it twice? Once as single workpoint and second as first point of rectangular pattern?
3. If the Workpoints and pattern should be sorted, we need something which defines the order. In the fx-parameter list, it can be the order of entries.
Maybe there are more questions in further progress.
R. Krieg
RKW Solutions
Message 9 of 18
r.claus
very nice to hear from you.
Regarding your questions:
1. Yes, the empty places must always be filled with "f". The names should stay in the first line. The same is true for the patterns. Maybe it is better to work with 4 to 30 workpoints.
2. The base workpoint of a rectangular pattern is a single workpoint or sometimes more workpoints, but it is selected only with the pattern. The base workpoint(s) should be listed only as the first point(s) of a rectangular pattern and not twice.
3. Yes, we can use the order of entries in the fx-parameter list. It is also possible to set them once.
Maybe better as example:
4 to 30 single workpoints with selectable names
0 to 10 points in pattern 1 (single workpoint as base point)
0 to 90 points in pattern 2 (pattern 1 as base pattern)
0 to 10 points in pattern 3 (single workpoint as base)
0 to 20 points in pattern 4 (3 single workpoints as base)
Feel free to ask me more questions.
Thank you
Message 10 of 18
Ralf_Krieg
Hello
First, I've noticed that multivalue parameters are always alphabetical sorted. That may be no problem with single workpoints. But for the pattern is the correct order of the patterns is necessary. You could always rename the patterns to "reorder" them, but I would prefer to create fx parameters for each pattern. For each pattern a pair of paramters. In the text parameter "PatternNameX" (where X is the order number) is the value the name of the pattern. In the numeric, unitless parameter "PatternFields" is the value the maximum number of pattern elements. This way, you can add more patterns and remove patterns and change the maximum field numbers. The picture shows the parameters for a scenario with workpoints 4 pattern features.
Hope all is as expected.
Option Explicit on
Class ThisRule
	Private Structure UWorkPoint
		Dim Name As String
		Dim Parent As String
		Dim X As String
		Dim Y As String
		Dim Z As String
	End Structure
	Private uWP As UWorkPoint
	Private uWorkPointList As List(Of UWorkPoint)
	Private uPatternList As List(Of UWorkPoint)
	Private sCaption As String
	Public Sub Main()
		Dim oDoc As PartDocument = ThisDoc.Document
		Dim fxNumber As String = String.Empty
		Dim fxCustomer As String = String.Empty
		Dim fxType As String = String.Empty
		Dim oWPs As New List(Of String)
		Dim iWPCount As Integer
		Dim oUserParam As UserParameter
		Dim iMaxCount As Integer = oDoc.ComponentDefinition.Parameters.UserParameters.Count
		Dim i As Integer
		Dim oPatternNames As New List(Of String)
		Dim oPatternNumbers As New List(Of String)
		uWorkPointList = New List(Of UWorkPoint)
		uPatternList = New List(Of UWorkPoint)
		sCaption = "iLogic Export Workpoints 2 CSV"
		For i = 1 To iMaxCount
			For Each oUserParam In oDoc.ComponentDefinition.Parameters.UserParameters
				Select Case oUserParam.Name.ToUpper
					Case "PATTERNNAME" & i : oPatternNames.Add(oUserParam.Value)
					Case "PATTERNFIELDS" & i : oPatternNumbers.Add(oUserParam.Value)
					Case "WP_FIELDS" : iWPCount = oUserParam.Value
					Case "WP_EXPORT"
						oWPs = SortList(MultiValue.List("WP_Export").Cast(Of String)().ToList())
						If oWPs.Count = 0 Then
							oWPs = New List(Of String)
							oWPs.Add(oUserParam.Value.ToString)
					Case "NUMBER" : fxNumber = oUserParam.Value
					Case "CUSTOMER" : fxCustomer = oUserParam.Value
					Case "TYPE" : fxType = oUserParam.Value
				End Select
			Next
		Next
		For Each item As String In oWPs
			IsWorkpoint(item, oDoc)
		Next
		Do While uWorkPointList.Count < iWPCount
			uWP = CreateuWP("SINGLE_Work Point")
			uWorkPointList.Add(uWP)
		Loop
		'search all patterns for the names in pattern list
		For i = 0 To oPatternNames.Count - 1
			IsRectPattern(oPatternNames.Item(i), oPatternNumbers.Item(i), oDoc)
			IsCircPattern(oPatternNames.Item(i), oPatternNumbers.Item(i), oDoc)
		Next
		ExportWorkpoints(uWorkPointList, fxNumber, fxCustomer, fxType)
	End Sub
	Private Sub IsWorkpoint(ByVal item As String, ByVal oDoc As PartDocument)
			If (item.ToUpper = oWP.Name.ToUpper) And (oWP.Visible = True) Then
				If oWP.IsCoordinateSystemElement = False Then
					uWP = CreateuWP("Single", oWP)
		Next
	End Sub
	Private Sub IsRectPattern(ByVal item As String, ByVal iColCount As Integer, ByVal oDoc As PartDocument)
		Try
				If item.ToUpper = oRPF.Name.ToUpper Then
					If oRPF.Suppressed = True Then
						MsgBox("Rectangular Pattern " & oRPF.Name & " is suppressed. Skipping and continue next", MsgBoxStyle.Information, sCaption)
					Else
						uPatternList.Clear()
						GetPointsRect(oRPF, oRPF.Name, iColCount)
						Do While uPatternList.Count < iColCount
							uWP = CreateuWP(oRPF.Name)
							uPatternList.Add(uWP)
						Loop
						uWorkPointList.AddRange(uPatternList)
			Next
		Catch ex As Exception
			Logger.Debug(ex.Message)
		End Try
	End Sub
	Private Sub IsCircPattern(ByVal item As String, ByVal iColCount As Integer, ByVal oDoc As PartDocument)
		Try
				If item.ToUpper = oCPF.Name.ToUpper Then
					If oCPF.Suppressed = True Then
						MsgBox("Circular Pattern " & oCPF.Name & " is suppressed. Skipping and continue next", MsgBoxStyle.Information, sCaption)
					Else
						GetPointsCirc(oCPF, oCPF.Name, iColCount)
							uWP = CreateuWP(oCPF.Name)
						Loop
			Next
		End Try
	End Sub
	Private Sub GetPointsRect(ByVal oPatternFeature As RectangularPatternFeature, ByVal sPatternFeature As String, ByVal iColCount As Integer)
		Try
			Dim i As Integer
			Dim j As Integer
							uWP = CreateuWP(sPatternFeature, oParentFeatures(i))
							If Not uWP.Name Is Nothing Then uPatternList.Add(uWP)
					Else
						uWP = CreateuWP(sPatternFeature)
						GetPointsRect(oParentFeatures(i), sPatternFeature, iColCount)
						GetPointsCirc(oParentFeatures(i), sPatternFeature, iColCount)
			Next
				If oPatternElements(i).Suppressed = False Then
										uWP = CreateuWP(sPatternFeature, oResultFeatures(j))
							Else
						Next
			Next
		End Try
	End Sub
	Private Sub GetPointsCirc(ByVal oPatternFeature As CircularPatternFeature, ByVal sPatternFeature As String, ByVal icolCount As Integer)
		Dim i As Integer
		Dim j As Integer
				Else
					GetPointsRect(oParentFeatures(i), sPatternFeature, icolCount)
					GetPointsCirc(oParentFeatures(i), sPatternFeature, icolCount)
		Next
							Else
					Next
		Next
	End Sub
	Private Sub ExportWorkpoints(ByVal uWorkPointList As List(Of UWorkPoint), ByVal fxNumber As String, ByVal fxCustomer As String, ByVal fxType As String)
		Dim i As Integer
		Dim j As Integer
		fileName = "CSV Name" & fxNumber & ".csv"
		Dim aFileData(3, uWorkPointList.Count + 3) As String
		aFileData(0, 0) = "Number"
		aFileData(1, 0) = fxNumber
		aFileData(0, 1) = "Customer"
		aFileData(1, 1) = fxCustomer
		aFileData(0, 2) = "Type"
		aFileData(1, 2) = fxType
		aFileData(0, 3) = "Name"
		aFileData(1, 3) = "X"
		aFileData(2, 3) = "Y"
		aFileData(3, 3) = "Z"
		For i = 4 To uWorkPointList.Count + 3
			Try
				aFileData(0, i) = uWorkPointList.Item(i - 4).Name
				aFileData(1, i) = uWorkPointList.Item(i - 4).X
				aFileData(2, i) = uWorkPointList.Item(i - 4).Y
				aFileData(3, i) = uWorkPointList.Item(i - 4).Z
			Catch
				aFileData(0, i) = "f"
				aFileData(1, i) = "f"
				aFileData(2, i) = "f"
				aFileData(3, i) = "f"
			End Try
		Next
		For i = 0 To 3
			For j = 0 To uWorkPointList.Count + 3
				expfile.Write(aFileData(i, j) & dlmtr)
			Next
		Next
		expfile.Close()
	End Sub
	Private Function CreateuWP(ByVal sPrefix As String, Optional ByVal oWP As WorkPoint = Nothing) As UWorkPoint
		If oWP Is Nothing Then
			'create Dummy entry
			uWP.Name = sPrefix & "_f"
			uWP.X = "f"
			uWP.Y = "f"
			uWP.Z = "f"
		Else
			' Check for duplicate in uworkpointlist
			If uWorkPointList.Exists(Function(x) x.Name = "Single_" & oWP.Name) = True Then
				Logger.Debug("Skipped duplicate workpoint " & oWP.Name)
				Return Nothing
			Else
				uWP = New UWorkPoint
				uWP.Name = sPrefix & "_" & oWP.Name
				uWP.X = Round(oWP.Point.X * 10, 2).ToString
				uWP.Y = Round(oWP.Point.Y * 10, 2).ToString
				uWP.Z = Round(oWP.Point.Z * 10, 2).ToString
		Return uWP
	End Function
	Private Function SortList(ByVal oSourceList As List(Of String)) As List(Of String)
		Dim listOfLines As New Dictionary(Of Integer, String)
		For Each line As String In oSourceList
			Dim part() As String = Line.Split(New Char() {"t"}, StringSplitOptions.RemoveEmptyEntries)
			listOfLines.Add(Integer.Parse(part(part.Length - 1)), Line)
		Next
		Dim listOfKeys As List(Of Integer) = listOfLines.Keys.ToList
		listOfKeys.Sort()
		Dim oSortedList As New List(Of String)
		For Each key As String In listOfKeys
			oSortedList.Add(listOfLines(key))
		Next
		Return oSortedList
	End Function
End Class
R. Krieg
RKW Solutions
Message 11 of 18
r.claus
thanks again for the help. The task is really not easy.
In line 46 I had to remove "SortList", otherwise I got an error message and I could only enter one workpoint in "WP_Export". Line 46: oWPs = (MultiValue.List("WP_Export").Cast(Of String)().ToList())
Since only one component with different active workpoints is being worked with, it should still be possible to make a selection. So which patterns and which individual workpoints should be exported. I would then create multiple rules that can be used for the particular case. Maybe using the fx-parameter list for selection would be better than after all or define a list like in your second code?
Besides that, it would be important that the workpoints in the CSV always keep the name (name of pattern). Without "sPrefix "_f". So, the name should be static per pattern and the point get a consecutive number (1 to max). Also, single workpoints should keep the same name from Inventor if they are invisible.
I noticed that invisible workpoints in the pattern are not included in the CSV. The names should remain in place, only the values should be replaced with "f".
For overview the attached CSV file. How the naming’s should be. The single workpoint 5 and the point 10 in the pattern "Workpoints_Rod" are invisible.
Do you think it is possible to implement these points?
I hope you can help me again. Thank you very much for your patience.
Message 12 of 18
Ralf_Krieg
Hello
Sorry, I have actual no time to look at this. But I will do as fast as I can.
R. Krieg
RKW Solutions
Message 13 of 18
r.claus
Thank you for message.
No problem, I look forward to hearing from you again soon.
Message 14 of 18
Ralf_Krieg
Hello
I rethink the program logic. I throw away the parameters for the workpoints and patterns to export. The parameters for number, customer and type remains.
All existing single Workpoints will be exported. Invisible Workpoints get an "f" in the 3 coordinate fields.
All patterns are exported, except they are entirely suppressed. This way we can have 2, 3, 4 or x pattern in the same file and only unsuppress the necessary. Cause of all unsuppressed patterns are exported, there's no need to define them in parameters. All Workpoints in the pattern will be exported. Invisible Workpoints within the pattern get an "f" in the 3 coordinate fields.
Single Workpoints that are base of a pattern will also be exported in the pattern (otherwise the number of columns vary), but get an "f" in the 3 coordinate fields. So the coordinates are not duplicated in the export file. Is this ok?
Can you give it a try and tell if we are closer to the solution?
Class ThisRule
		Dim Name As String
		Dim X As String
		Dim Y As String
		Dim Z As String
	End Structure
	Private iWPCount As Integer
	Public Sub Main()
			End Select
		Next
		ProcessWorkpoints(oWPs,oDoc)
		Dim oFeature As Object
		For Each oFeature In oDoc.ComponentDefinition.Features
			iWPCount=1
			If TypeOf oFeature Is Inventor.RectangularPatternFeature Then
				ProcessRectPattern(oFeature, oDoc)
			ElseIf TypeOf oFeature Is Inventor.CircularPatternFeature Then
				ProcessCircPattern(oFeature, oDoc)
		Next
	End Sub
	Private Sub ProcessWorkpoints(ByVal oWPs As List(Of String), ByVal oDoc As PartDocument)
			If oWP.IsPatternElement = False Then
				logger.debug(oWP.Name)
				uWP = CreateuWP(oWP, 0,"Single")
				If uWP.Name IsNot Nothing Then uWorkPointList.Add(uWP)
				logger.debug(uWP.Name)
		Next
	End Sub
	Private Sub ProcessRectPattern(ByVal oRPF As RectangularPatternFeature, ByVal oDoc As PartDocument)
		Try
				logger.debug("Rectangular Pattern " & oRPF.Name & " is suppressed. Skipping and continue next")
			Else
				GetPointsRect(oRPF, oRPF.Name)
			Logger.Debug("ProcessRectPattern" & vbCrLf & ex.Message)
		End Try
	End Sub
	Private Sub ProcessCircPattern(ByVal oCPF As CircularPatternFeature, ByVal oDoc As PartDocument)
		Try
				logger.debug("Circular Pattern " & oCPF.Name & " is suppressed. Skipping and continue next")
			Else
				GetPointsCirc(oCPF, oCPF.Name)
			Logger.Debug("ProcessCircPattern" & vbCrLf & ex.Message)
		End Try
	End Sub
	Private Sub GetPointsRect(ByVal oPatternFeature As RectangularPatternFeature, ByVal sPatternFeature As String)
		Try
			Dim i As Integer
			Dim j As Integer
					uWP = CreateuWP(oParentFeatures(i), iWPCount,sPatternFeature)
						iWPCount += 1
					If oParentFeatures(i).Suppressed = False Then GetPointsRect(oParentFeatures(i), sPatternFeature)
					If oParentFeatures(i).Suppressed = False Then GetPointsCirc(oParentFeatures(i), sPatternFeature)
			Next
								uWP = CreateuWP(oResultFeatures(j), iWPCount,sPatternFeature)
									iWPCount += 1
						Next
			Next
			Logger.Debug("GetPointsRect" & vbCrLf & ex.Message)
		End Try
	End Sub
	Private Sub GetPointsCirc(ByVal oPatternFeature As CircularPatternFeature, ByVal sPatternFeature As String)
		Try
			Dim i As Integer
			Dim j As Integer
						iWPCount += 1
			Next
								uWP = CreateuWP(oResultFeatures(j), iWPCount, sPatternFeature)
									iWPCount += 1
						Next
			Next
			Logger.Debug("GetPointsCirc" & vbCrLf & ex.Message)
		End Try
	End Sub
		Dim i As Integer
		Dim j As Integer
			Try
			Catch
			End Try
		Next
		For i = 0 To 3
			Next
		Next
		expfile.Close()
	End Sub
	Private Function CreateuWP(ByVal oWP As WorkPoint, ByVal iWPCount As Integer, Optional ByVal sPatternName As String = "") As UWorkPoint
		If oWP.IsCoordinateSystemElement = True Then Return Nothing
		Dim sPatternString As String = ""
		If sPatternName.ToUpper = "SINGLE" Then
			sPatternString=oWP.Name
		Else
			sPatternString = "Workpoints_" & sPatternName & "_" & iWPCount
		If oWP.Visible = False Then
			'create Dummy entry
			uWP.Name = sPatternString '& oWP.Name
			uWP.X = "f"
			uWP.Y = "f"
			uWP.Z = "f"
			Return uWP
		If sPatternName = "" Then
			'create Dummy entry
			uWP.Name = sPatternString 'oWP.Name
			uWP.X = "f"
			uWP.Y = "f"
			uWP.Z = "f"
			Return uWP
		If uWorkPointList.Exists(Function(x) x.Name = oWP.Name) = True Then
			'create as dummy, to keep column count but prevent duplicate coordinates
			uWP.X = "f"
			uWP.Y = "f"
			uWP.Z = "f"
			Return uWP
		Return uWP
	End Function
End Class
R. Krieg
RKW Solutions
Message 15 of 18
r.claus
nice to hear from you again.
It's better, but I think we misunderstood each other a little.
Sorry for that.
Message 16 of 18
r.claus
Maybe it would be enough to use the second code from 11-12-2021 and integrate that invisible workpoints (individually and in patterns) are not removed (names remain, values become "0").
I used your second code with a rule to rename the workpoints for each pattern. Do you know a way to use a separate "oWorkPointColl" for each pattern in your code? So I hope to create for each pattern (group of workpoints) a block like below. Because I need a fixed number of workpoints for each type of pattern. (I only need the Y component for each workpoint)
For i = 9 To 50
			Try
				afiledata(0, i) = oWorkPointColl(i-8).Name
				'afiledata(1, i) = Round(oWorkPointColl(i-3).Point.X * 10, 1)
				afiledata(1, i) = Round(oWorkPointColl(i-8).Point.Y * 10 -5, 2)
				'afiledata(3, i) = Round(oWorkPointColl(i-3).Point.Z * 10, 1)
			Catch
				afiledata(0, i) = "Entw" & k
				afiledata(1, i) = "0"
				'afiledata(2, i) = "0"
				'afiledata(3, i) = "0"
				k=k+1
			End Try
Message 17 of 18
Ralf_Krieg
Hello
Sorry for the very late reply.
If I don't skip the invisible workpoints in the code of my second post (which is not a problem), you will have the alphabetical sort order of the fx-parameter multi value list and the workpoints of the patterns are not renamed. See the version below.
You can create a separate object collection for each pattern and another one for the single work points. Object collections don't have a name property, so all collections are anonymous. You have to find a way to identify the different collections if you want to fill it up with dummy entries to a defined limit somewhere later in your program.
Option Explicit on
Class ThisRule
	Private Sub Main
'	"WorkPoints1", _
'	"WorkPoints4", _
	' use the automatic alphabetical sort order of the multi value list
	Dim Features= MultiValue.List("WP_Export").Cast(Of String)().ToList()
		Next
		Next
				oSelSet.Select(oWP)
		Next
				Logger.Debug(item)
			Next
	Dim oSel As Object
	            'If oSel.Visible = True Then
	            'End If
	    End Select
	Next
	oSelSet.Clear
	End Sub
	    Dim i As Integer
	    Dim j As Integer
	    Next
	                    'If oResultFeatures(j).Visible = True Then
	                    'End If
	            Next
	    Next
	End Sub
	    Dim i As Integer
	    Dim j As Integer
	    Next
	                    'End If
	            Next
	    Next
	End Sub
		Dim i As Integer
		Dim j As Integer
		For i = 4 To 103
			Try
			Catch
			End Try
		Next
		For i = 0 To 3
			For j = 0 To 103
			Next
		Next
		expfile.Close
	End Sub
End Class
R. Krieg
RKW Solutions
Message 18 of 18
r.claus
thank you very much for your reply.
I was able to find a way to separate the workpoints.
Wish you a merry christmas and a happy new year.
