dxf
dxf
GosponZ
dxf
GosponZ
This code worked years back, and i just start to use again and have problem. I got error Argument 'Length' must be greater or equal to zero. Could you guys help to solve this problem. Thank you
oPath = ThisDoc.Path
        oFileName = ThisDoc.FileName(False) 'without extension
        oDXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
        oDocument = ThisApplication.ActiveDocument
        oContext = ThisApplication.TransientObjects.CreateTranslationContext
        oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        oOptions = ThisApplication.TransientObjects.CreateNameValueMap
        oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
        'Define the drawing
        Dim oDrawing As DrawingDocument
        oDrawing = ThisDoc.Document
        Dim oSheet As Sheet
        Dim lPos As Long
        Dim rPos As Long
        Dim sLen As Long
        Dim sSheetName As String
        Dim sSheetNumber As Integer
        'step through each drawing sheet
Dim Response As MsgboxResult
        For Each oSheet In oDrawing.Sheets
            Response = MsgBox("Yes = Save or No = Continue to next Sheet?", MsgBoxStyle.YesNo, "Question")
            If Response = MsgBoxResult.Yes Then
                'find the seperator in the sheet name:number
                lPos = InStr(oSheet.Name, ":")
                'find the number of characters in the sheet name
                sLen = Len(oSheet.Name)
                'find the sheet name
                sSheetName = Left(oSheet.Name, lPos - 1)
                'find the sheet number
                sSheetNumber = Right(oSheet.Name, sLen - lPos)
ActiveSheet = ThisDrawing.Sheet(oSheet.Name)
                'get DXF target folder path
                oFolder = "C:\TEMP"
                'Set the DXF target file name
                oDataMedium.FileName = oFolder & "\" & sSheetName & sSheetNumber & ".dxf"
                MessageBox.Show("DXF SAVED TO: " & oDataMedium.FileName, "DXF Saved", MessageBoxButtons.OK)
                'Publish document
                oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
        Next
 I hgit error Argument 'Length' must be greater or equal to zero
GosponZ
My bad code is working fine. I had sheets turned off form counting and printing.
