Turn on all tangent edges in all views
aurel_e
aurel_e
I'm looking for an I-logic rule to turn on all the tangent edges in all the views in multi-sheets drawings.
Inventor 2020.
Thank you.
JhoelForshav
Hi @aurel_e
Try this:
Dim oDoc As DrawingDocument = ThisDrawing.Document
For Each oSheet As Sheet In oDoc.Sheets
	For Each oView As DrawingView In oSheet.DrawingViews
		oView.DisplayTangentEdges = True
	Next
Next
aurel_e
Hi @JhoelForshav
It isn't working. This is the message;
For what I can see, it's working just for the first sheet.
JhoelForshav
Hi @aurel_e
For some views it's not possible to turn on tangent edges
This will do it for all views that allow it:
		On Error Resume Next
	Next
Next
oDoc.Update
dgreatice
Hi all,
you need filtering about viewstyle:
Dim oDoc as DrawingDocument = ThisDrawing.Document
For Each oSheet In oDoc.Sheets
    For Each oView In oSheet.DrawingViews
        If Not oView.ViewStyle = kFromBaseDrawingViewStyle Then
            oView.DisplayTangentEdges = False
        End If
    Next
Next
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
aurel_e
@JhoelForshav
It's perfect now.
Thank you.
octavio.olivaEUAB9
Disculpa esta configuración donde la inserto para obtener de forma automática cada dibujo que cree, las aristas Tangentes?
