trying to add specific text to custom sketch symbol
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all
im trying to get a macro to work but its being stubborn (or i dont know enough coding)
the macro, as it is now, adds user input text from a form into a drawing.
but since that not all of our drawings are the same scale and even orientation of the sheet i got the idear to use the sketch symbol since that is on the template of all drawings since we beforehand filled in manually
but here is my problem, how do i make the macro find the sketch symbol and insert the user input text according to the position of the symbol?
i have attached a screenshot where i have marked where im trying to place the text, the code i have now does place the text there but as statet, if the layout differs it does not work
I have show the code below
(also this is my first post, so if i have done something the incorrect way, by all means tell me and also if you see redundant coding or errors do tell im learning as i try)
Function fileExists(fname) As Boolean
If Dir(fname) <> "" Then fileExists = True Else fileExists = False
End Function
Public Sub data()
'Print all sheets in drawing document
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MsgBox "This is NOT an assembly document!", vbExclamation
Exit Sub
End If
Dim oPrintMgr As PrintManager
Set oPrintMgr = ThisApplication.ActiveDocument.PrintManager
If MsgBox("Using default printer """ & oPrintMgr.Printer & """ Do you want to continue?", vbYesNo + vbQuestion) = vbNo Then
Exit Sub
End If
Dim oDrgPrintMgr As DrawingPrintManager
MsgBox "Using printer " & oPrintMgr.Printer & ", Color, Best Fit, 11x17 paper, Landscape."
dirPath = Left(oAsmDoc.FullFileName, Len(oAsmDoc.FullFileName) - Len(oAsmDoc.DisplayName))
Dim oRefDocs As DocumentsEnumerator
Set oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
numFiles = 0
Dim form As New UserForm1
form.Show
'Print assembly drawing
idwPathName = Left(oAsmDoc.FullDocumentName, Len(oAsmDoc.FullDocumentName) - 3) & "idw"
If fileExists(idwPathName) Then
numFiles = numFiles + 1
'If numFiles = 10 Then Exit Sub
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
ThisApplication.CommandManager.ControlDefinitions.Item("AppZoomallCmd").Execute
oDrawDoc.Activate
Set oDrawDoc = ThisApplication.ActiveDocument
Set oDrgPrintMgr = oDrawDoc.PrintManager
oDrgPrintMgr.AllColorsAsBlack = False
oDrgPrintMgr.ScaleMode = kPrintBestFitScale
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
Dim oActiveSheet As Sheet
Set oActiveSheet = oDrawDoc.ActiveSheet
' Set a reference to the GeneralNotes object
Dim oGeneralNotes As GeneralNotes
Set oGeneralNotes = oActiveSheet.DrawingNotes.GeneralNotes
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
' Create text using various overrides.
sText1 = form.TextBox1
Set oGeneralNote1 = oGeneralNotes.AddFitted(oTG.CreatePoint2d(5, 25.75), sText1)
sText = form.TextBox2
Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(8, 25.75), sText)
Dim oDrgDoc As DrawingDocument
Set oDrgDoc = ThisApplication.ActiveDocument
' Set the printer name
' comment this line to use default printer or assign another one
'Set the paper size , scale and orientation
oDrgPrintMgr.PaperSize = kPaperSizeA4
oDrgPrintMgr.PrintRange = kPrintAllSheets
oDrgPrintMgr.Orientation = kLandscapeOrientation
oDrgPrintMgr.SubmitPrint
oGeneralNote.Delete
oGeneralNote1.Delete
oDrawDoc.Close (True)
End If
For Each oRefDoc In oRefDocs
Dim oType As String
oType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
If oRefDoc.SubType = oType Then
Else
idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw"
'Dim oDrawDoc As DrawingDocument
oDrawDoc.Activate
Dim ActiveDocument As Sheet
Set ActiveDocument = oDrawDoc.ActiveSheet
Dim oGeneralNotes2 As GeneralNotes
Set oGeneralNotes2 = ActiveDocument.DrawingNotes.GeneralNotes
Dim oGeneralNotes3 As GeneralNotes
Set oGeneralNotes3 = ActiveDocument.DrawingNotes.GeneralNotes
Set oGeneralNote = oGeneralNotes2.AddFitted(oTG.CreatePoint2d(5, 25.75), sText1)
Set oGeneralNote = oGeneralNotes3.AddFitted(oTG.CreatePoint2d(8, 25.75), sText)
End If
' Printer setup, default printer
oPrintMgr.ColorMode = kPrintDefaultColorMode ' Set to default
oPrintMgr.NumberOfCopies = 1 ' Set to print one copies.
oPrintMgr.Orientation = kLandscapeOrientation ' Set to print using landscape orientation.
oPrintMgr.PaperSize = kPaperSizeTabloid 'Set the paper size.
oPrintMgr.SubmitPrint ' Submit the print.
End If
Next
MsgBox "There are " & numFiles & " sent to printer."
End If
End Sub
