VBA how do i change the library/folder it looks in ?
Darkforce_the_ilogic_guy
Advisor Advisor
I have a problem that after move to a new computer and to inventor 2024, that now it can´t find the ilogic code. IT seens to not looking the right folder any more.  How do I change this so it look in the right folder ?
Private Sub SharedViews_Click()
Dim addIn As ApplicationAddIn
    Dim addIns As ApplicationAddIns
    Set addIns = ThisApplication.ApplicationAddIns
        For Each addIn In addIns
            If InStr(addIn.DisplayName, "iLogic") > 0 Then
                            addIn.Activate
                Dim iLogicAuto As Object
                Set iLogicAuto = addIn.Automation
                Exit For
        Next
    Debug.Print addIn.DisplayName
    Dim RuleName1 As String
    EXTERNALrule = "SharedViews"
    'Dim RuleName2 As String
    'INTERNALrule = "Rule2"
      Dim oDoc As Document
      Set oDoc = ThisApplication.ActiveDocument
      If oDoc Is Nothing Then
        MsgBox "Missing Inventor Document"
        Exit Sub
    'iLogicAuto.RunRule oDoc, INTERNALrule 'for internal rule
    iLogicAuto.RunExternalRule oDoc, EXTERNALrule 'for external rule
End Sub
sdf
Curtis_Waguespack
I am asking about VBA. I use VBA userform to aktivere ilogic. After we have installe a test PC with inventor 2024. I seens to not able to find the ilogic files. I believe that it for some reasom looks in the wrong folder.
 the files normal is locate in this folder
but for some reason it can not find the files anymore. So my question is how to I get the VBA code to look in the right folder?
mslosar
Application Options/File Tab/VBA Folder section.
