Triggering Routines remotely
Isn't there any work around, no matter how archaic, to make an iLogic routine run from a completely different document than the one it's in? I have tried everything from remotely changing properties to even editing a sketch in the model to try an trigger a routine. Nothing works. I have set triggers to fire when the part opens but opening the documents with code doesn't fire those triggers. It’s very frustrating to have to open each part in an assembly manually just to get all the routines to run.
Please tell me I'm doing something wrong or that there is a work around that actually works!
Note I'm using 2012.
Thanks in advance!
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
Using Inventor 2018
