Evaluation like holeTable
Hy, i am quiet new in inventor API.
In a part or assembly i want to find all holes. i can access all the holeFeatures, but if the user has copied or mirrored the feature, the hole itself is not in the list
i have found this code
      Try
            Dim oDoc As PartDocument
            oDoc = _invApp.ActiveDocument
            Dim oDef As PartComponentDefinition
            oDef = oDoc.ComponentDefinition
            Dim lHoleFeatureCount As Long
            lHoleFeatureCount = oDef.Features.HoleFeatures.Count
            Dim lHoleCount As Long
            lHoleCount = 0
            Dim oHoleFeature As HoleFeature
            For Each oHoleFeature In oDef.Features.HoleFeatures
                lHoleCount = lHoleCount + oHoleFeature.HoleCenterPoints.Count
            Next
            MsgBox("There are " & lHoleFeatureCount & " hole features and " & _
               lHoleCount & " holes in the part.")
        Catch ex As Exception
            showCatchMessage("Irgendwas ging schief!", ex.Message)
        End Try
In a drawing i can place a holeTable with all the holes inside.
What is the right access to reach also those holes, which do not come directly from the HoleFeature.
Thanks for any kind of help
YuhanZhang
Can you refer to this post: http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/How-can-I-get-all-the-holes-in-a-Part-....
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
