Triggering Routines remotely
meck
meck
Isn't there any work around, no matter how archaic, to make an iLogic routine run from a completely different document than the one it's in? I have tried everything from remotely changing properties to even editing a sketch in the model to try an trigger a routine. Nothing works. I have set triggers to fire when the part opens but opening the documents with code doesn't fire those triggers. It’s very frustrating to have to open each part in an assembly manually just to get all the routines to run.
Please tell me I'm doing something wrong or that there is a work around that actually works!
Note I'm using 2012.
Thanks in advance!
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
skyngu
meck
Thanks for the link!
I have to admit it is working a bit better but there still are many parts that do not trigger when an assembly is opened. I realize that iLogic is just getting started, but I hope Autodesk looks into a way of remotely triggering routines to force the issue.
Thanks again!
Mike Eck
Using Inventor 2018
MjDeck
In an assembly, you can run a rule in a component using a statement like:
iLogicVb.RunRule("ComponentA:1",  "RuleInPart1")
If you are opening documents with code, you can run rules in them like this:
Dim otherDoc as Document = ...
auto = iLogicVb.Automation
auto.RunRule(otherDoc, "OtherRuleName")
Mike Deck
Software Developer
Autodesk, Inc.
