Transient cylinder
Transient cylinder
pveng
Transient cylinder
pveng
Hello all,
I need a segment of a transient cylinder.
The parameters in cylindrical coordinate system are: r1, r2, y1, y2, phi1, phi2.
I have the problem to define the angles phi1 and phi2.
Unfortunately the function 'oTransientBRep.CreateSolidCylinderCone' only uses r and y as parameters. One can only build full cylinders with this function.
I tried to split up the cylinder with a plane at the required angle, but this doesn't work.
This is my code:
Public Sub CreateSegmentCylinder()
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
Dim otg As TransientGeometry
Set otg = ThisApplication.TransientGeometry
Dim oTransientBRep As TransientBRep
Set oTransientBRep = ThisApplication.TransientBRep
Dim r1, r2, y1, y2, phi1, phi2 As Double
r1 = 1
r2 = 2
y1 = 0
y2 = 1
phi1 = 0
phi2 = 20
Dim p1 As Point
Set p1 = otg.CreatePoint(0, y1, 0)
Dim p2 As Point
Set p2 = otg.CreatePoint(0, y2, 0)
Dim oCylinder1 As SurfaceBody
Set oCylinder1 = oTransientBRep.CreateSolidCylinderCone(p1, p2, r1, r1, r1)
Dim oCylinder2 As SurfaceBody
Set oCylinder2 = oTransientBRep.CreateSolidCylinderCone(p1, p2, r2, r2, r2)
' Cut oCylinder2 with oCylinder1
Call oTransientBRep.DoBoolean(oCylinder2, oCylinder1, kBooleanTypeDifference)
Dim p3 As Point
Set p3 = otg.CreatePoint(Cos(phi1 / 180 * pi), y1, Sin(phi1 / 180 * pi))
Dim oplane As plane
Set oplane = otg.CreatePlaneByThreePoints(p1, p2, p3)
' How can the transient cylinder split with the plane?
'Call oCompDef.Features.SplitFeatures.SplitBody(oplane, oCylinder2)
' Create a base feature with the result body.
Dim oBaseFeature As NonParametricBaseFeature
Set oBaseFeature = oCompDef.Features.NonParametricBaseFeatures.Add(oCylinder2)
End Sub
Thanks for your help
When you try to make a point:
in my opinion it doesn't make sense.
You need 3 coordinates set in mm(or inches), but Cos(phi1 / 180 * pi) is an unitless thing. It should be multiplied by some metric value (probably r1 or r2).
Could you draw how this cylinder segment should (more ir less) look like?
pveng
Thanks Thomasz for the quick reply,
p3 is only for the plane definition. 3 points define a plane, p1 and p2 are on the y-axis and p3 is away from the y-axis. The distance from the axis isn't needed, only the angle of the plane. For example phi1 = 0 then p3=(1, y1, 0) and therefore the x-y-plane. If phi=90° then p3=(0, y1, 1) and therefore the y-z-plane.
The problem is to create a transient geometry like the picture below. As Feature it is not a problem to create, but I need some thousands of this objects, which means, transient geometry is a lot more efficient.
