Change text based on code
caio.guimaraes7LVGH
caio.guimaraes7LVGH
Greetings!
I'll just outright explain what I need and then explain what I'm trying.
I need to indicate in a drawing sheet its size. Thus, if it's A4, then I want to appear somewhere on the screen: "A4 210x297".
What I'm trying to do is: making a piece of code that reads what's the name of the sheet format and changes a parameter. Then I wanted to change a text field based on that parameter. I failed on my first step, so I came here before even trying the second one.
So, if you may help me, I wanted to ask two things:
  • Is there a easier way to do this? Mind you, I wanted it to be completely automated: we already have 5 different sheet formats with different sizes.
  • Regardless if there is, I'd like to do this with iLogic and VBA because I wanted to learn. Is there a way to do this?
    • Proceeding with this code, how do I go about changing a text field based on a parameter I created? I have a parameter called test. Can I simply go on about a particular field and set it for its contet to be the same value as parameter 'test'? I have NO clue as to how to go about this.
My code was a rule I created with this written:
Sub main()
Sheet_size = ThisDrawing.ActiveSheet.Name
Parameter(test) = text_return(Sheet_size)
End Sub
Function Sheet_size(sheet As String) As String
	If sheet Is "A4"
		text = "A4 xx.xx"
End Function
Trying this returns me with an error: Parameter: Could not find a parameter named: ""
I'm currently in a A4 sized sheet.
You cas try this code (iLogic)
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim SheetSize = oDoc.ActiveSheet.Size
If SheetSize = kA0DrawingSheetSize Then
	text = "AAA"
Else If SheetSize = kA1DrawingSheetSize Then
	text = "BBB"
Else If SheetSize = kA2DrawingSheetSize Then
	text = "CCC"
Else If SheetSize = kA3DrawingSheetSize Then
	text = "DDD"
Else If SheetSize = kA4DrawingSheetSize Then
	text = "EEE"
It will change "text" parameter depending on size of sheet.
caio.guimaraes7LVGH
It worked to change the parameter, thanks!
Still atempting to input the parameter in the text label, following this instruction but not quite getting it to work.
