Tracking Un-ballooned components in Drawing?
Yadow
Yadow
Hey guys,
I wonder if anyone might know how to ether highlight or print out compontents that does not have a balloon attached to them already?
I am fairly new to Programming, but learning to create my own Macros. If I find a solution I will post it here :).
Best Wishes,
Tobias.
MechMachineMan
Option Compare Text
Class DwgCheck
	Shared oDoc As Document
	Shared oSheet As Sheet
	Shared oProgressbar As ProgressBar
	Shared oTextSave As String = "C:\Users\Public\Documents\iLogic Buffer File.txt"
	Shared oWrite As Object
	Shared oStr1 As String
	Shared oStr2 As String
	Shared oStr3 As String
	Shared oStr4 As String
	Shared oStr5 As String
	Shared oStr6 As String
	Shared Sub Main()
		Dim oPartsList As PartsList
		Dim oRow As PartsListRow
		Dim oCell As PartsListCell
		oWrite = System.IO.File.CreateText(oTextSave)
		oWrite.WriteLine("Parts List Content Check")
		oDoc = ThisApplication.ActiveDocument
		oProgressBar = ThisApplication.CreateProgressBar(False, oDoc.Sheets.Count, "Pre-Issue Drawing Check Status")
		For j = 1 To oDoc.Sheets.Count
			oSheet = oDoc.Sheets.Item(j)
			oSheet.Activate
			oProgressBar.Message = ("Translating Data. Current Sheet: " & j & "/" & oDoc.Sheets.Count & vbLf & oSheet.Name)
			oProgressBar.UpdateProgress
			'Clear the string variables
			oStr1 = ""
			oStr2 = ""
			oStr3 = ""
			oStr4 = ""
			oStr5 = ""
			oStr6 = ""
			Call CheckDims()
			Call CheckSymbols()
			Call CheckPartsLists()
			Try
				If oStr1 = "" And oStr2 = "" And oStr3 = "" And oStr4 = "" And oStr5 = "" And oStr6 = ""
				Else
					oWrite.WriteLine("")
					oWrite.WriteLine("#-------" & oSheet.Name)
					If oStr1 <> ""
						oWrite.WriteLine("## Balloons: " & oStr1)
					If oStr2 <> ""
						oWrite.WriteLine("## Custom Line: " & oStr2)
					If oStr4 <> ""
						oWrite.WriteLine("## Static Line: " & oStr4)
					If oStr3 <> ""
						oWrite.WriteLine("## Descrip: " & oStr3)
					If oStr5 <> ""
						oWrite.WriteLine("## : " & oStr5)
					If oStr5 <> ""
						oWrite.WriteLine("## : " & oStr6)
			Catch
				oWrite.WriteLine()
				oWrite.WriteLine("FAILED: " & oSheet.Name & " - " & oDoc.FullFileName)
				oWrite.WriteLine()
				Continue For
			End Try
		Next'Sheet
		oProgressBar.Close
		oWrite.Close()
		Process.Start ("Notepad.exe",oTextSave)
	End Sub
	Sub CheckDims()
		Dim oDims As DrawingDimensions
		oDims = oSheet.DrawingDimensions
		If oDims.Count = 0
				oStr5 = AddToString(oStr5, " and ", "Missing Dims!")
		For Each oDim As DrawingDimension In oDims
			If oDim.Attached = False
				oStr5 = AddToString(oStr5, " and ", "Broken!")
				Exit For
		Next
	End Sub
	Sub CheckSymbols()
		Dim oSketched As SketchedSymbol
		For Each oSketched In oSheet.SketchedSymbols
			For Each oTextBox In oSketched.Definition.Sketch.TextBoxes
				If oTextBox.Text = ""
					oStr6 = AddToString(oStr6, " and ", "Blank Sketched TextBox Found!")
					Exit For
			Next
		Next
	End Sub
	Sub CheckPartsLists()
		If oSheet.PartsLists.Count = 0
			Exit Sub
		For j = 1 To oSheet.PartsLists.Count
			oPartsList = oSheet.PartsLists.Item(j)
			For Each oRow In oPartsList.PartsListRows
				'Check Balloons
				If oRow.Ballooned = False
					oStr1 = AddToString(oStr1, ", ", oRow.Item("LINE").Value)
				'Check Custom Rows
				If oRow.Custom = True
					oStr2 = AddToString(oStr2, ", ", oRow.Item("LINE").Value)
				'Check 1/8" plate, A569, UNF, or gauge plate
				If oRow.Item("DESCRIPTION").Value Like "*A569*" Or _
					oRow.Item("DESCRIPTION").Value Like "*Gr*.*5*" Or _
					oRow.Item("DESCRIPTION").Value Like "*UNF*" Or _
					oRow.Item("DESCRIPTION").Value Like "*PL. 1/8*"
					oStr3 = AddToString(oStr3, "vblf", oRow.Item("LINE").Value & ") " & oRow.Item("DESCRIPTION").Value)
				If oRow.ReferencedRows.Item(1).BOMRow.ComponentDefinitions.Item(1).Type() = ObjectTypeEnum.kVirtualComponentDefinitionObject
					'Do nothing
				Else
					If Not oRow.Item("DESCRIPTION").Value.Length = oRow.ReferencedRows.Item(1).BOMRow.ComponentDefinitions.Item(1).Document.PropertySets.Item("Design Tracking Properties").Item("Description").Value.Length
						oStr4 = AddToString(oStr4, ", ", oRow.Item("LINE").Value)
					'MsgBox(oRow.Item("ITEM").Value)
			Next 'Row
		Next 'PartsLists
	End Sub
	Function AddToString(oStorageString As String,oSeparator As String, oDetail As String) As String
		If oStorageString = ""
			oStorageString = oDetail
		Else
			If oSeparator Like "vblf"
				oStorageString = oStorageString & vbLf & oDetail
			Else
				oStorageString = oStorageString & oSeparator & oDetail
		Return oStorageString
	End Function
	Function DocNameWExt(oName As String)
		oPos = Len(oName) - InStrRev(oName, "\", -1) 'Position left Right = Length of string - Position of "\" from right side
		oNameWExt = Right(oName, oPos)               'Name with Extension = Everything to the right of the oPos
		Return oNameWExt
	End Function
End Class
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Yadow
Thank you so much for the code 🙂 Is this for iLogic? Is there any way I could ask you for a translation of this code into VBA-code?
If not then I´ll take this and learn what I can from it.
Many thanks once again!
MechMachineMan
The main differences between vba and vb.net (which iLogic is based on) are:
Vba needs to use "On Error Resume" clauses whereas vb.net uses the more
intuitive try/catch.
Vba requires common variable type assignments to be preceded by "Set".
Other than that, there might be a few small things, but changing these 2
things could get it completely working for you.
Justin K
