Tolerance is not showing?
Hello!
I would like to put different tolerances depending on the value and tried something like below but the tolerance is not showing on the drawing. Can anyone advise me what am I doing wrong? Thank you in advance!
If (oParam.Value <= 15) Then
    oParam.Tolerance.SetToSymmetric(0.1)
ElseIf (oParam.Value >15) AndAlso (oParam.Value <= 30) Then
    oParam.Tolerance.SetToSymmetric(0.15)
Else
    oParam.Tolerance.SetToSymmetric(0.2)
Btw I can see tolerances are correctly applied in the parameter of .ipt but they are not shown in the drawing.
bradeneuropeArthur
hi, could you upload the complete code to investigate?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Hi Arthur,
Thank you for your reply.
I wrote code something like this.
Dim oValue As Inventor.Parameter
oValue = params.Item("value.Name")
oValue.Tolerance.SetTosymmetric("0.2 mm")
The complete code is a bit long but you can find it on my github. See line 90.
https://github.com/Minso-xyz/automated-drawing-backup.ring/blob/master/backup_ring/backup_ring/Form1...
Thank you for your help!
marcin_otręba
hi,
how is your dimensions in drawing created ? it is retrived from model like :
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
or placed directly in drawing ? - if yes then tolerance will not occur in your drawing.
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
@marcin_otręba
Hi Marcin,
I tried "Retrieve Model Annotations" as you suggested and it works now! Thank you!!
