Toggle on/off VDS in Inventor
johan.degreef
Advisor Advisor
Message 1 of 8
johan.degreef
Can anyone help to make a toggle button (as there was in the past) to toggle on/off the Vault Data standards in Inventor Add-in?
Many Thanks, Johan
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Replies (7)
Message 2 of 8
basautomationservices
I would say you just find the application add-ins ID, but when I print all app add-ins, the Vault Data Standard does not show up.
Sub test()
Dim addin As ApplicationAddIn
For Each addin In ThisApplication.ApplicationAddIns
    Debug.Print (addin.DisplayName)
    Debug.Print (addin.ClientId)
    Debug.Print ("-----")
Next
End Sub
So I looked in here for the .addin file to find the GUID:
And found it is "{3ad251e3-02dd-4b8c-8882-86c97c80e00c}"
Here's the toggle script. You can create a button either by creating a button for a VBA macro or creating a iLogic rule, (and creating a button for this).
Sub Toggle()
Set addin = ThisApplication.ApplicationAddIns.ItemById("{3ad251e3-02dd-4b8c-8882-86c97c80e00c}")
If addin.Activated Then
    Call addin.Deactivate
Else
    Call addin.Activate
End Sub
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
Message 3 of 8
johan.degreef
Thank you, but this seems not to fit in an external iLogic rule, should it?
Sub Toggle()
Else
    Call addin.Activate
End Sub
Message 4 of 8
What I wrote was VBA.
For an iLogic rule it should be:
Else
    Call addin.Activate
Message 5 of 8
johan.degreef
Thank you!
Message 6 of 8
bradeneuropeArthur
Klein add-in tje schrijven voor je, Johan!
Write a small add-in!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 7 of 8
bradeneuropeArthur
If you are interested in this Add-in, please send me a private message.
Arthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 8
bradeneuropeArthur
Does something like this add-in make sense?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
