To View the Model Normal to .FlatPattern.BaseFace for DXF Export
SevInventor
SevInventor
I have an ilogic rule for exporting the flat pattern to DXF
Before the export it asks the user if the thing has the right orientation but at that time it only shows the current View position which can be moved and rotated.
So it isn’t an indicator for correct orientation.
In Inventor 2019 there was no problem because in the flat pattern the View was never rotated and always showing normal to the flat pattern.
How can I view the standard Orientation  as in earlier versions.
Basically I want the To View the Model Normal to  .FlatPattern.BaseFace when the message box shows up.
I've tried arround with oview and ocamera and stuff but no success yet.
thanks
'Flip Alignment Type
' Set a reference to the active document.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
'ensure this part has a flat pattern
Dim oSMDef As SheetMetalComponentDefinition
oSMDef = oPartDoc.ComponentDefinition
If oSMDef.FlatPattern Is Nothing Then
'create flat pattern
oSMDef.Unfold
Else
End If
Question = MessageBox.Show("Is the orientation correct?" ,"leave it or flip?" ,MessageBoxButtons.YesNo)
If Question = vbNo Then
'oCompDef.FlatPattern.FlipBaseFace
Dim oAlignmentType As AlignmentTypeEnum
Dim oAlignedTo As Object
Dim oAlignmentDirection As Boolean
'get current alignment parameters
oSMDef.FlatPattern.GetAlignment(oAlignmentType, oAlignedTo, oAlignmentDirection)
'toggle alignment horizontal/ vertical parameter
'kHorizontalAlignment = 64257
'kVerticalAlignment = 64258
If oAlignmentType = 64257  Then
oAlignmentType = 64258
Else
End If
oSMDef.FlatPattern.SetAlignment(oAlignmentType, oAlignedTo, oAlignmentDirection)
End If
'zoom all
ThisApplication.ActiveView.Fit
JelteDeJong
Just to be clear you want your users to check if the alignment settings are set correctly. And with alignment settings I mean these settings:
Maybe a bit silly but if the orientation is not correct then you can make the user change the settings himself/herself. To help them you could open the dialog for them. Something like this:
Dim doc As PartDocument = ThisDoc.Document
Dim def As SheetMetalComponentDefinition = doc.ComponentDefinition
def.Unfold()
Dim question = MessageBox.Show("Is the orientation correct? (If not correct the orientation manualy and restart this rule)", "Check orientation", MessageBoxButtons.YesNo)
If question = DialogResult.No Then
    ThisApplication.CommandManager.ControlDefinitions.Item("SheetMetalEditFlatCtxCmd").Execute()
    Return ' Exit the rule
End If
Jelte de Jong
Blog: hjalte.nl - github.com
SevInventor
Hello Jelte,
always nice to hear from the superstars in this forum. I've learned a lot from your contributions. Thanks.
Yes i want the same thing but without that dialog/ command.
The view can also be wrong during this dialog so it's not quite clear how the result will be as output see picture.
Its clearer if the view is perpendicular to the flat pattern.
JelteDeJong
Is this what you are looking for?
def.Unfold()
Dim flatPattern As FlatPattern = def.FlatPattern
Dim camera = ThisApplication.ActiveView.Camera
Dim question = DialogResult.No
While question <> DialogResult.Yes
    camera.ViewOrientationType = ViewOrientationTypeEnum.kFrontViewOrientation
    camera.Fit()
    camera.Apply()
    Dim orientation As FlatPatternOrientation = flatPattern.FlatPatternOrientations.ActiveFlatPatternOrientation
    ' Dim AlignmentAxis As Object = Orientation.AlignmentAxis '<-- probaly an edge
    If (orientation.AlignmentType = AlignmentTypeEnum.kVerticalAlignment) Then
        orientation.AlignmentType = AlignmentTypeEnum.kHorizontalAlignment
    Else
    End If
End While
''' Your code to export comes here.
Jelte de Jong
SevInventor
Yes, almost.
I've never imagined that
would always be the right view but I've tested it on some sheetmetal files and it was working on all of them.
This code works for me:
Ive added:
def.FlatPattern.Edit
and moved the position of the message box in the code
def.Unfold()
    camera.Fit()
    camera.Apply()
    Else
    End If
End While
Thank you Jelte
SevInventor
better:
def.Unfold()
    camera.Fit()
    camera.Apply()
question = MessageBox.Show("Is the orientation correct? " & vbCr & vbCr &
"On ESC correct the orientation manualy and restart this rule", "Check orientation",  MessageBoxButtons.YesNoCancel)
'msgbox(question)
'While question <> DialogResult.Yes
 While question = DialogResult.No
    Dim orientation As FlatPatternOrientation = FlatPattern.FlatPatternOrientations.ActiveFlatPatternOrientation
    Else
    End If
    camera.Fit()
    camera.Apply()
End While
If question = DialogResult.Cancel Then
End If
