To Update Mass by iLogic Rule Running from Within Drawing
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
I am interested in updating mass of the assembly in the drawing document by running a rule from the drawing.
By running this in the drawing, nothing happens.
Could someone help me.
Thanks.
ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
iLogicVb.UpdateWhenDone = True
Sergio.D.Suárez
Hi, To use the command you propose I think you should have an access like the following
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oViewModelDoc As Document
For Each oSheet As Sheet In oDoc.Sheets
	For Each oView As DrawingView In oSheet.DrawingViews
		oViewModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
		oViewModelDoc = ThisApplication.Documents.Open(oViewModelDoc.fullfilename, True)
		oViewModelDoc.activate
		oViewModelDoc.Close
	Next
Next
 However, I think there should be another more direct access, if I find something I will tell you below. Cheers
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Sergio.D.Suárez
Here are some threads that maybe they can serve you.
https://forums.autodesk.com/t5/inventor-customization/assemby-mass-update/m-p/5519134/highlight/true...
https://forums.autodesk.com/t5/inventor-customization/vba-check-if-mass-update-is-required/td-p/7565...
Mechanical Designer
RoyWickrama_RWEI
Thanks a lot.
It does well for my needs.
yuriboutique10
Community Visitor
Community Visitor
Can you help me the ilogic related to update mass for many opened drawing in this document? Thanks.
nick_panzarino
I had a similar problem and used the below rule to resolve it. Set to "Run Before Save" using event triggers.
Sub Main()
	' Check that the active document is a drawing  file
	If ThisApplication.ActiveDocument.DocumentType <> kDrawingDocumentObject Then
		MessageBox.Show("Please run this rule from a drawing file.", "iLogic")
		Exit Sub
	End If
	' Set a reference to the drawing document.
	Dim oDrawDoc As DrawingDocument
	oDrawDoc = ThisApplication.ActiveDocument
	Dim oRefDoc As Inventor.Document
	For Each oRefDoc In oDrawDoc.ReferencedDocuments
		'MsgBox(oRefDoc.DisplayName)
		updateMass(oRefDoc)
	Next
	oDrawDoc.Update2(True)
End Sub
Function updateMass(oDoc As Inventor.Document)
	If oDoc.DocumentType = kPartDocumentObject Or oDoc.DocumentType = kAssemblyDocumentObject Then
		Dim oMassProps As Inventor.MassProperties
		oMassProps = oDoc.ComponentDefinition.MassProperties
		If oMassProps.AvailableAccuracy <> 24579 And oMassProps.AvailableAccuracy <> 24580 Then
	      oMassProps.Accuracy = 24579 'Inventor.AccuracyEnum.kHigh
	      oMassProps.CacheResultsOnCompute = True
	    End If
		Dim readMass As Double
		readMass = oMassProps.Mass
	End If
End Function
