Assembly Hole Feature Depth Bug
ianteneth
Message 1 of 11
ianteneth
Version: Inventor Professional 2020.2
Question: Is the depth property of an assembly hole feature implemented in the API? Or am I running into some other issue?
I am running into an error when I try to get the depth of an assembly hole feature (ie. a hole feature that is in the assembly and not in a part). It appears that this section of code has not yet been implemented. Below is the error message.
Not implemented (Exception from HRESULT: 0x80004001 (E_NOTIMPL))
Below is a screenshot of an example assembly with hole features in the assembly.
Below is a code snippet that will try to get the depth of the hole features in the assembly.
Sub Main()
	Dim assembly As AssemblyDocument = ThisDoc.Document
	For Each hole As HoleFeature In assembly.ComponentDefinition.Features.HoleFeatures
		MessageBox.Show(hole.Depth) 'Crashes here.
	Next hole
End Sub
I did a little searching before and this might be related to this issue, but I am not sure.
https://forums.autodesk.com/t5/inventor-customization/depth-value-for-the-hole-is-missing-from-paren...
Replies (10)
Message 2 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@ianteneth,
Please provide non confidential file to test the behavior?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 11
WCrihfield
Remembe that within the () of a MessageBox.Show(), it is expecting a certain order of things within.
The first section is usually "String" type data.
You may have to define this value as a string before it will show up like you want.
Try this:
Sub Main()
Dim oDepth As String
oDepth = hole.Depth.ToString MessageBox..Show(oDepth,"Hole Depth") Next hole End Sub
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 11
WCrihfield
Remember that within the () of a MessageBox.Show(), it is expecting a certain order of things within.
The first section is usually a "String" type data (message).  And the second section is the 'Title' (also String).
You may have to define this value as a string before it will show up like you want with the MessageBox.
Try This:
Sub Main()
		MessageBox.Show(oDepth,"Hole Depth")
	Next hole
End Sub
Wesley Crihfield
Message 5 of 11
ianteneth
@WCrihfieldThanks for the feedback! I have modified the code to show that the Messagebox.Show() method is not causing the error. This code yields the same error as I mentioned before.
@chandra.shekar.gI have attached a zipped folder containing an example assembly for you to test.
Sub Main()
		Dim holeDepth = hole.Depth 'Crashes here.
	Next hole
End Sub
Message 6 of 11
WCrihfield
either do:
or:
Dim holeDepth As Double
If using "Dim" it is expecting you to define its type, not its value.
Wesley Crihfield
Message 7 of 11
ianteneth
@WCrihfield I updated the code to your recommendations (See below). It still crashes in the same way. I don't think the issue is the the variable instantiation. Thanks anyways!
And also, I forgot to mention that this issue was originally discovered in the C# api. So it is not limited to iLogic.
Sub Main()
		holeDepth = hole.Depth ' Crashes here
	Next hole
End Sub
Message 8 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@ianteneth,
To address this issue, a change request (INVGEN - 35947 - Depth of hole feature in Assembly document throws exception) is created with engineering team.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 11
etaCAD
Just an assumption: Is there a valid depth value when the hole is a through hole?
Andreas
etaCAD
Message 10 of 11
WCrihfield
Good question.  Although retrieving the Depth of a hole that goes through multiple parts in an assembly file currently creates an error, as stated above.  Within a normal part file, you can create a hole feature, set to Through All, and when you retrieve its depth by iLogic, it returns a number equal to the thickness of the part (when both starting face & ending face are flat).
Though it is often forgotten that when features are created within a Part file, then attempting to access & use those features to support further processing within the assembly file, you almost always will need to create & work with a 'proxy' of that feature.  That way you're not modifying the original part, but instead are working with a copy/representation of that feature, created within the Assembly.
Wesley Crihfield
Message 11 of 11
ianteneth
This has reportedly been fixed in the 2021.1 update. I haven't tested it yet.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Inve...
