To retrieve Appearances from the current Appearance Library
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
Ref: Inventor part document:
In my iLogic pursuits, currently I need to have all the appearances (from the current Appearance library) in a pull down menu so that desired appearance can be selected. The selected appearance to be assigned to the part. Similar to the following, but for the appearances.
Thanks.
Dim oMaterials As New ArrayList
For Each oMaterial In ThisDoc.Document.Materials
'msg = MessageBox.Show(oMaterial.Name, "Title",MessageBoxButtons.OKCancel)
oMaterials.add(oMaterial.Name)
If msg = vbCancel Then
Exit For
End If
Next
'present the user with the list to choose from
100:
oMaterial_IP = InputListBox("CHOOSE MATERIAL FROM ABOVE LIST", oMaterials, oMaterials.item(0), "MATERIAL SELECTION", "LIST OF MATERIALS")
If oMaterial_IP = "" Then Goto 100:
iProperties.Material = oMaterial_IP
t_hascj
You can get appearances from active library byt this code
ThisApplication.ActiveAppearanceLibrary.AppearanceAssets
Jaroslav
RoyWickrama_RWEI
Hi Jaroslav (t_hascj)
With the help of your hint and getting more help from the forum, O got around mu need.
Sub oAppearance_Sub()
Dim oLib As AssetLibrary
Dim sAppearance As String
Dim invAppearanceProperty As Inventor.Property
'oLib = ThisApplication.AssetLibraries("Autodesk Appearance Library")
oLib = ThisApplication.AssetLibraries("RWEI TEXTURES")
Dim oTextures As New ArrayList
For Each oTexture In ThisApplication.ActiveAppearanceLibrary.AppearanceAssets
'oMsg = MessageBox.Show(oTexture.DisplayName, "Title",MessageBoxButtons.OKCancel)
oTextures.add(oTexture.DisplayName)
Exit For
End If
Next
100:
oTextures_Selected = InputListBox("CHOOSE TEXTURE FROM ABOVE LIST", oTextures, oTextures.item(0), "TEXTURE SELECTION", "LIST OF TEXTURES")
If oTextures_Selected = "" Then Goto 100:
MessageBox.Show("oTextures_Selected: " & oTextures_Selected, "Title")
oPartDoc = ThisDoc.Document		'oCompDef.Document
oPartDoc.ActiveAppearance.DisplayName = oTextures_Selected
End Sub
RoyWickrama_RWEI
I found it was not working though it did well before. So, I revised the code as follows:
Sub Main()
oAppearance_Sub()
ThisDoc.Save
End Sub
Dim oPartDoc As Inventor.PartDocument = ThisApplication.ActiveDocument
Dim oAppearanceAssets As AssetsEnumerator
oAppearanceAssets = oPartDoc.AppearanceAssets
Dim oAsset As Asset
Dim oAsset_Array As New ArrayList
For Each oAsset_Array_X In ThisApplication.ActiveAppearanceLibrary.AppearanceAssets
oAsset_Array.add(oAsset_Array_X.DisplayName)
Exit For
End If
Next
100:
oAsset_Array_Selected = InputListBox("CHOOSE TEXTURE FROM ABOVE LIST", oAsset_Array, oAsset_Array.item(0), "TEXTURE SELECTION", "LIST OF TEXTURES")
If oAsset_Array_Selected = "" Then Goto 100:
oAsset_X = oAsset_Array_Selected
For Each oAsset In oAppearanceAssets
	'Loop through the assetsvalues, that you see in the appearance dialogbox
    Dim oAssetValue As AssetValue
	'oMsgBox = MessageBox.Show("oAsset: " & oAsset.DisplayName, "oAsset")
	If oAsset.DisplayName = oAsset_X Then
	oPartDoc.ActiveAppearance = oAsset
	Exit For
	End If
Next
End Sub
C.Lourenco
Observer
Observer
I tried to use the code like this and it doesn't show the list of appearances, it shows something else. I'm trying this code to later create a multivalue parameter to use in a form.
'oLib = ThisApplication.AssetLibraries("Kubor_Aparencias")
oTextures.Add(oTexture.Name)
Exit For
End If
Next
100:
oTexture_Selected = InputListBox("CHOOSE TEXTURE FROM ABOVE LIST", oTextures, oTextures.Item(0), "TEXTURE SELECTION", "LIST OF TEXTURES")
'If oTexture_IP = "" Then GoTo 100 :
oPartDoc.ActiveAppearance.DisplayName = oTexture_Selected
matt_jlt
Here is the code that i am using. ITs a bit more complicated because i created a form within iLogic but it does the same thing with some extra options.
https://github.com/mattjlt/Inventor-Code-Library/blob/master/Scripts/MOD_Set%20All%20Colours.iLogicV...
