Error in rule
Error in rule
Error in rule
Tengo  el siguiente problema con ilogic. no se como expresarlo así que  adjunto una imagen para ver si alguien puede entenderlo.
agradecía si alguien me puede ayudar,
gracias
Translated with Google Translate:
I have the following problem with ilogic. I do not know how to express it so I attached an image to see if anyone can understand it.
thank you if anyone can help me,
thanks
MechMachineMan
exactly as the writing says, it can't find the component.
Either the format you typed the component in as isn't as expected, or there is issues with your naming. Try searching up stabilizing browser nodes and do that, or just run the rename browser nodes command, tweak the rule, and try rerunning.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
dgreatice
Hi Marquez,
did you use suppressed component inside the ilogic code?
because i see level of detail 1 was create.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
