To Automate the Dimension using curves in a view
I have created sheets of all the parts in a assembly and have scaled the views to fit into the sheet, now I am faced with automating the dimensioning of the view in the sheet, I am iterating through the sheets and in that I am selecting an view, now comes the main part where I have to iterate the curves in this view and have dimension put into the view on the sheet.
Is it possible to do this, I have been asked to do this without using attribute or select line segment.
any help will be appreciated.
yan.gauthier
Hi, It is completely possible to do. In fact, I built an algorithm to do this.
Here the steps you should take:
-List every straight lines (one list for vertical, one for horizontal. you can use DrawingCurve.Curve.Segments.item(1).Geometry.Direction to tell if the curve is horizontal or vertical)
-List every concave circle or arc centerpoint
-Compare their coordinate in order to keep only one value per coordinate (e.g.: 2 hole on the same horizontal axis)
-Reorder them in the right order
-Generate Geometry intents from their mid points
-Add dimensions between your first point in the list (origin) and every points.
*I recommend using Dictionnaries to simplify filtering
You might need to develop some special function to snap on circle quadrants and whatnot.
It is a big task to do. I actually rewrote my code in C# addin and was able to go from 3000+ lines of code to 800 lines and execution is much better.
Here is a example of my first prototype of code:
https://i.imgur.com/ZXE0Mr0.mp4
Thanks, I was going in the same direction, will try to complete it.
yan.gauthier
I don't know how well versed you are in programming, but I used an object oriented approach for this task (yes, it is possible in VBA)
I created a class for the curves, one for the holes, one for the dimensions, one for the geometry intent. That way, I could use a factory approach to when adding them to a collection class and integrate into the add method a check to see if there is already an equivalent element in my collection (e.g.: annotate a specific hole only once)
as an example: here the content of my class named cHoles which interact with my class cHole and other class. The Add method act as a factory and checks the type of hole it is (check the PartFeature to get the right diameter) and make sure to add it only once (dictionary .exists method shines here).
I give you this, because I know getting the feature from the part is difficult. the only way to find the feature if the curve selected was generated from a pattern feature, is to use the .[CreatedByFeatures] property which is not documented by Autodesk.
Option Explicit
Private HoleList As New Collection
Private HoleDictList As Object
Private RadiusDictList As Object
Public Property Get Hole(Key As Integer) As cHole
' Error Handling for non-existing curves
    Err.Clear
    On Error Resume Next
    Set Hole = HoleList.item(Key)
    If Err Then
        Debug.Print "hole does Not exist"
    Err.Clear
End Property
Public Property Get count() As Integer
    count = HoleList.count
End Property
Public Sub add(ByVal oCurve As DrawingCurve)
' Recieve a circle DrawingCurve, will look if created from a hole feature or not
' Redundancy are not filter yet at this stage
Dim oFace As Face
Dim oFeature As Object
Dim oHole As cHole
Dim oHoleFeature As HoleFeature
Dim Radius As Double
Dim HoleFeatBigDiameter As Double
Dim oSheet As Sheet
Dim intent As GeometryIntent
Dim Cmark As Centermark
Dim oView As DrawingView
'Create Centermark
Set oView = oCurve.Parent
Set oSheet = oView.Parent
Set intent = oSheet.CreateGeometryIntent(oCurve)
Set Cmark = oSheet.Centermarks.add(intent)
'If HoleDictList Is Nothing Then 'Initialize hole feature filter dictionary
'    Set HoleDictList = CreateObject("Scripting.Dictionary")
'End If
'If RadiusDictList Is Nothing Then 'Initialize circle filter dictionary
'    Set RadiusDictList = CreateObject("Scripting.Dictionary")
'End If
If oCurve.ProjectedCurveType = kCircleCurve2d Or oCurve.ProjectedCurveType = kCircularArcCurve2d Then 'Make surce oCurve is a circle or a circle arc
    Set oHole = New cHole
    Set oHole.Curve = oCurve
    oHole.FeatureName = ""
    If Not oView.IsFlatPatternView Then
        For Each oFace In oCurve.ModelGeometry.Faces 'Loop through corresponding faces connected to the hole curve
            'Prevent working with FaceProxies (meaning hole is not created in this document, Happens in assemblies)
            If Not TypeOf oFace Is FaceProxy And TypeOf oFace Is Face Then
                If oFace.SurfaceType = kCylinderSurface Or oFace.SurfaceType = kConeSurface Then
                    ' Loop through features participating in creation of the hole, this way, we can find the parent feature
                    ' of a repetition feature or a mirror feature
                    For Each oFeature In oFace.[_CreatedByFeatures]
                        If TypeOf oFeature Is HoleFeature Then
                            Set oHoleFeature = oFeature
                            oHole.FeatureName = oHoleFeature.name
                            'Add place dimension on cbore or csink diameter, not inner diameter
                            Select Case oHoleFeature.HoleType
                                Case kCounterBoreHole
                                    HoleFeatBigDiameter = oHoleFeature.CBoreDiameter.Value 'Value is in centimeter
                                Case kCounterSinkHole
                                    HoleFeatBigDiameter = oHoleFeature.CSinkDiameter.Value 'Value is in centimeter
                                Case Else
                                    HoleFeatBigDiameter = 0
                            End Select
                            ' Make sure curve is outer diameter and feature not already in use
                            If Round(oCurve.ModelGeometry.Geometry.Radius * 2, 4) >= Round(HoleFeatBigDiameter, 4) Then
                                If Not HoleDictList.exists(oHoleFeature.name) Then
                                    HoleDictList.add oHoleFeature.name, True  ' Add to dictionary for future filtering
                                    HoleList.add oHole
                                    Exit For
                    Next oFeature
        Next oFace
    ' If no hole feature was found, then consider as regular circle (will be general dimension instead of holenote)
    If oHole.FeatureName = "" Then
        Radius = Round(oCurve.Segments.item(1).Geometry.Radius, 4)
        If Not RadiusDictList.exists(Radius) Then
            RadiusDictList.add Radius, True 'Add to dictionnary for future filtering
            oHole.Radius = Radius
            oHole.OccurrenceNumber = 1
            HoleList.add oHole
        Else 'Find the hole with same radius and change occurrence value +1
            AddOccurrence Radius
End Sub
Private Sub AddOccurrence(ByVal Radius As Double)
' Add + 1 to ohole occurrence
Dim oHole As cHole
For Each oHole In HoleList
    If oHole.Radius = Radius Then
        oHole.OccurrenceNumber = oHole.OccurrenceNumber + 1
        Exit For
Next oHole
End Sub
Private Sub Class_Initialize()
' Event lauched at the first initialization of the class
End Sub
happy coding
I am fairly new to coding and just recently got introduced to Inventor, so thank you.
nebi_guler
@yan.gauthier @Anonymous  Hello guys, I opened a topic on the forum about the problem I was experiencing, then while doing research, I came across this post. I need help on this exact issue. I want to take measurements from the cross-sectional measurements or the outer lines of any view of the models in the "Sheet". I am developing with C#. I have no problem converting from VB.NET to C#. If you can help me, I would be happy and we will contribute to the community together through supportive communication. I will leave the post link below. If you have time, please wait for your answers below the post. Best regards.
https://forums.autodesk.com/t5/inventor-programming-ilogic/taking-the-roughest-measurements-in-a-vie...
