Logic that is loaded by selecting settings for each product when loading an assembly
jklim
Observer Observer
jklim
Observer
Observer
First of all, I'm not good at English so I'm sorry for asking questions through a translator.
I have been using Inventor for over 7 years, but I am a novice designer who has just started ilogic design and has never used in-depth design methods.
The content of the question is the same as the title of the article.
When importing an assembly, I would like to import the assembly by selecting the specifications of the individual items used in each assembly.
I have applied all the rules and forms to the individual products, but when I load each individual product into the assembly, I can set it, but when I read the assembled product again, I have to go into the individual product and make the settings.
Also, if you design a base and select 'Base A', I wonder if it is possible to set 'Base B, Base C, Base D...' of other shapes and sketches to be excluded from the assembly.
Lastly, is it possible to register an assembly created in this way as an assembly with selectable settings in the Content Library Center?
Sorry for the rambling questions I had to ask through a translator. I need expert help.
A.Acheson
Hi @jklim
I think you are looking for ilogic place component command to place ilogic assembly and change parameters. See link here.
If you are looking  to control parts inclusion in the assembly you can either delete and add each time or suppress. Suppressing is made easier in later inventor versions with model states.
For content center no assemblies are not supported. Only parts are supported.
Regards
Alan
jklim
Observer
Observer
Thank you Mr. ACHESON
Since you asked the question through a translator, your intention may not have been conveyed accurately, but I did read your reply.
In the end, you have to double-click each product and select the specifications individually. I don't think you can do it while loading.
First, we will wait for other answers. Can I decide then whether to accept it or not?
