Titlebox changes size, goes beyond border
sanganaksakha
sanganaksakha
I am facing a strange problem, and I suspect it could be a bug.
I am creating a new drawing using VB.Net using the following code I found on the forum:
oDrawing = curIvApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, _
curIvApp.GetTemplateFile(DocumentTypeEnum.kDrawingDocumentObject), False)
oFrontView = oSheet.DrawingViews.AddBaseView(oDocToDraw, insPtFrontView, viewScale,
ViewOrientationTypeEnum.kFrontViewOrientation,
DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
It works and creates the drawing. The code also adds the DWG NO in the drawing which is the same as the name of the linked model document.
But the titlebox size changes and it goes beyond the border on the left side. (See image.)
When I do it interactively, everything is fine.
On observation I found that the font size of the Part No. is larger than the font size when done manually?
1. Why does the font size change?
2. But more serious issue is why the titlebox changes the size. It should never happen. Is this a bug. I am using A4 size sheet, portrait. Inventor 2014.
I am really stumped.
bradeneuropeArthur
Test if the sketch of the title block is fully contraint!
You could also completely ground the sketch of the title block manually.
But do it in the template file!!!!!!!!
This should solve the problem from moving outside the border.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
sanganaksakha
1. I am using the default ISO template. So is it flawed? I don't think so.
2. Why the font size of the PART NO is larger than when I do it interactively, is still not clear.
