Title Block Copy - Equivalent to a double-click on the Drawing Resource
shastu
Advisor Advisor
shastu
This should be so simple but I can't get it accomplished.  I have the code that copies the Drawing Resources in and then all I need is to add it to the active sheet.  I have looked online and tried several different things but nothing works.  The Title Block has prompted entries and is called ANSI A.  Here is the code that I have.
Sub TitleBlockCopy()
    Dim oSourceDocument As DrawingDocument
    Set oSourceDocument = ThisApplication.ActiveDocument
    ' Open the template drawing to copy the title block from.
    Dim oNewDocument As DrawingDocument
    ' if you put false here at the end it will not open visible, so you won't need to close it
    Set oNewDocument = ThisApplication.Documents.Open("Q:\Inventor\Templates_v2014\Templates\part.idw", False)
    ' Get the new title block definition.
    Dim oNewTitleBlockDef As TitleBlockDefinition
    'make sure that in your template.idw the needed titleblock is active
    Set oNewTitleBlockDef = oNewDocument.ActiveSheet.TitleBlock.Definition
    ' Set the new title block definition.
    Dim oSourceTitleBlockDef As TitleBlockDefinition
    Set oSourceTitleBlockDef = oNewTitleBlockDef.CopyTo(oSourceDocument)
    ' Iterate through the sheets.
    Dim oSheet As Sheet
    For Each oSheet In oSourceDocument.Sheets
oSheet.Activate
Dim oTitleBlock As TitleBlock
'THE BELOW LINE IS THE PART THAT I CAN'T GET TO WORK.
Set oTitleBlock = oSheet.AddTitleBlock("ANSI A")
     Next
End Sub
demuff
Is the AddTitleBlock method throwing an error or does it just do nothing? Have you tried passing in the actual title block object rather than the string name?
MechMachineMan
I found your problem.
For a TB with 1 prompted entry:
Dim sPromptStrings(0) As String
sPromptStrings(0) = ""
 OR For 2:
Dim sPromptStrings(0 To 1) As String
sPromptStrings(1) = ""
Extrapolate this if it has more...
Also, look here for the API Documentation on add titleblock....
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-F9EB14F1-F2D8-41CC-8B61-07B9A5478267
ex://
Set oTitleBlock = oSheet.AddTitleBlock("ANSI A",, sPromptStrings)
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Shawn,
Yes, it is very simple.
Make sure that before adding title block, existing title block should be deleted.
    Dim oSourceDocument As DrawingDocument     Set oSourceDocument = ThisApplication.ActiveDocument        ' Open the template drawing to copy the title block from.     Dim oNewDocument As DrawingDocument     ' if you put false here at the end it will not open visible, so you won't need to close it     Set oNewDocument = ThisApplication.Documents.Open("Q:\Inventor\Templates_v2014\Templates\part.idw", False)        ' Get the new title block definition.     Dim oNewTitleBlockDef As TitleBlockDefinition     'make sure that in your template.idw the needed titleblock is active     Set oNewTitleBlockDef = oNewDocument.ActiveSheet.TitleBlock.Definition        ' Set the new title block definition.     Dim oSourceTitleBlockDef As TitleBlockDefinition     Set oSourceTitleBlockDef = oNewTitleBlockDef.CopyTo(oSourceDocument)        ' Iterate through the sheets.     Dim oSheet As Sheet     For Each oSheet In oSourceDocument.Sheets oSheet.Activate
Call oSheet.TitleBlock.Delete
Dim oTitleBlock As TitleBlock Set oTitleBlock = oSheet.AddTitleBlock("ANSI A")             Next End Sub
One more point, title block "ANSI A" should be available in Drawing resources of activedocument.
Please feel free to contact if there is any doubt.
If solve your problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Hi
i have copied your code and pasted in VBA editor... the code works fine upto deleting Title block and showing an error exactly at below mentioned line...
Please help...
Thanks in Advance.
shastu
Well,  As mentioned above, my problem was that I had prompted entries.  I assume that is your problem as well.  So I wanted to capture the information that was already in the prompted entries and retain that information so that once I brought in the updated title block that I would not lose that information.  I also wanted to make sure that I went through all pages and updated the title block on each and every page.  Here is the code I came up with but you will have to modify it to match your prompted entry titles.
Sub Update_TitleBlock(OrigFileLoc, oDocIDW, DerivedPartOriginalFile, SavedName)
 Dim oDocIDWStyles As Inventor.DrawingStylesManager
 Set oDocIDWStyles = oDocIDW.StylesManager
 Dim i As Integer
On Error Resume Next
 'Update Sytles to Global
 For i = 1 To oDocIDWStyles.Styles.Count
' Debug.Print "Styles - " + oDocIDWStyles.Styles.Item(i).Name
 If oDocIDWStyles.Styles.Item(i).UpToDate = False Then
 'MsgBox oDocIDWStyles.Styles.Item(i).Name
 If oDocIDWStyles.Styles.Item(i).Name = "ANSI" Then
oDocIDWStyles.Styles.Item(i).UpdateFromGlobal
 If oDocIDWStyles.Styles.Item(i).Name = "Bradbury-H" Then
 Next
    If (oDocIDW.DocumentType <> kDrawingDocumentObject) Then Exit Sub
    Dim oTemplate As DrawingDocument
    Dim oSheet As Sheet
    Dim titlename As String
    Dim oPane As BrowserPane
    Dim oDocumentNode As BrowserNode
    Dim oDrawingResourceNode As BrowserNode
    Set oSheet = oDocIDW.ActiveSheet
    Set oTitleBlock = oSheet.TitleBlock
        If oTitleBlock.Definition.Sketch.TextBoxes Is Nothing Then Exit Sub
            Set oTextBoxes = oTitleBlock.Definition.Sketch.TextBoxes
            For Each oTextBox In oTextBoxes
            'MsgBox oTextBox.Text
                If oTextBox.Text = "MJS" Then
                   'MsgBox ("This is a Part")
                   fname = "Bradbury Template.idw"
                   GoTo DoneWithThisFor
                ElseIf oTextBox.Text = "Enter Raw Stock Noun" Then
                   fname = "PART.idw"
                    'MsgBox SecondDescr
                ElseIf oTextBox.Text = "CROSS-SECTION" Then
                   'MsgBox ("This is a Cross Section")
                   fname = "Cross Section.idw"
                ElseIf oTextBox.Text = "MACHINE TYPE" Then
                    'MsgBox ("This is a LUBE TEMPLATE")
                   fname = "LUBETEMPLATE.idw"
                ElseIf oTextBox.Text = "MISCELLANEOUS MATERIALS" Then
                    'MsgBox ("This is a MISC_INSTALL")
                   fname = "MISC_INSTALL.idw"
                 ElseIf oTextBox.Text = "INSTALLATION DRAWING" Then
                    'MsgBox ("This is a INSTALLATION DRAWING")
                   fname = "RT Installation.idw"
                   Else
                   fname = "ASSY.idw"
            Next
'End of Extraction
DoneWithThisFor:
    Dim a As Integer
    Dim b As Integer
    Dim c As Integer
    Dim d As Integer
    Dim e As Integer
    Dim f As Integer
    Dim Count As Integer
    Dim TitleBlockArray() As Variant
    Dim oBorderDefinition As BorderDefinition
    Dim oTitleBlockDefinition As TitleBlockDefinition
If fname = "Cross Section.idw" Then
    Set oTemplate = ThisApplication.Documents.Open(ThisApplication.FileOptions.TemplatesPath & fname, False)
    Set oSourceTitleBlockDef = oTemplate.ActiveSheet.TitleBlock.Definition
    Set oNewTitleBlockDef = oSourceTitleBlockDef.CopyTo(oDocIDW, True)
    oTemplate.Close
    Count = oDocIDW.Sheets.Count * 3
    a = 0
    b = 1
    c = 2
    d = 3
    e = 4
    f = 5
   ReDim TitleBlockArray(Count) As Variant
     For Each oSheet In oDocIDW.Sheets
        If oSheet.TitleBlock Is Nothing Then Exit Sub
                If oTextBox.Text = "Enter Second Line Description" Then
                    SecondDescr = oTitleBlock.GetResultText(oTextBox)
                ElseIf oTextBox.Text = "PART No." Then
                    PartNo = oTitleBlock.GetResultText(oTextBox)
                ElseIf oTextBox.Text = "SCALE" Then
                    SCALEtxt = oTitleBlock.GetResultText(oTextBox)
               Next
Array4text:
   TitleBlockArray(a) = SecondDescr
   TitleBlockArray(b) = PartNo
   TitleBlockArray(c) = SCALEtxt
a = a + 3
b = b + 3
c = c + 3
 Count = Count - 1
   Next
'Delete the Titleblock from all sheets
For oSheetNumber = 1 To oDocIDW.Sheets.Count
            Set oSheet = oDocIDW.Sheets(oSheetNumber)
Next
 For Each oTitleBlockDefinition In oDocIDW.TitleBlockDefinitions
    If oTitleBlockDefinition.Name = "ANSI A" Then
        oTitleBlockDefinition.Delete
 Next
    Set oNewDocument = ThisApplication.Documents.Open(ThisApplication.FileOptions.TemplatesPath & fname, False)
    Set oSourceTitleBlockDef = oNewTitleBlockDef.CopyTo(oDocIDW)
    oNewDocument.Close
    Count = Count - 1
    Dim FinalCount As Integer
    FinalCount = Count
    Count = 0
oSheet.Activate
a = Count
b = Count + 1
c = Count + 2
SavedName = Right(SavedName, Len(SavedName) - 3)
SavedName = "BCO-" & SavedName
Dim sPromptString(0 To 6) As String
sPromptString(0) = SavedName
sPromptString(1) = TitleBlockArray(a)
sPromptString(2) = ""
sPromptString(3) = TitleBlockArray(c)
sPromptString(4) = ""
sPromptString(5) = ""
sPromptString(6) = ""
sPromptString(7) = ""
'Puts Titleblock back in to sheet
Set oTitleBlock = oSheet.AddTitleBlock("ANSI A", , sPromptString)
Count = Count + 3
Next
Else
    oTemplate.Close
'    Dim a As Integer
'    Dim b As Integer
'    Dim c As Integer
'    Dim Count As Integer
    a = 0
    b = 1
    c = 2
'   Dim TitleBlockArray() As Variant
                    Noun = oTitleBlock.GetResultText(oTextBox)
                ElseIf oTextBox.Text = "Enter Raw Stock Description" Then
                    RawStock1Desc = oTitleBlock.GetResultText(oTextBox)
               Next
'Array4text:
   TitleBlockArray(b) = Noun
   TitleBlockArray(c) = RawStock1Desc
a = a + 3
b = b + 3
c = c + 3
 Count = Count - 1
   Next
Next
' Dim oBorderDefinition As BorderDefinition
' Dim oTitleBlockDefinition As TitleBlockDefinition
 Next
'    Dim oNewDocument As DrawingDocument
    oNewDocument.Close
    Count = Count - 1
'    Dim FinalCount As Integer
    FinalCount = Count
    Count = 0
oSheet.Activate
a = Count
b = Count + 1
c = Count + 2
Dim sPromptStrings(0 To 3) As String
sPromptStrings(0) = TitleBlockArray(a)
sPromptStrings(1) = TitleBlockArray(b)
sPromptStrings(2) = TitleBlockArray(c)
sPromptStrings(3) = ""
Set oTitleBlock = oSheet.AddTitleBlock("ANSI A", , sPromptStrings)
Count = Count + 3
Next
    Exit Sub
End Sub
