Tag SubAssembly to "Phantom"
Does anyone have the API codes to tag a sub assembly as Phantom in the BOM?
something like : If the part number of the sub assembly equals "RUN---" then tag it as "Phantom"?
Thank you.
Raj
bshbsh
just to give you the idea, you can do something like this:
Private Sub phantom()
    For Each Occurrence In ComponentDefinition.Occurrences
        If Occurrence.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = "RUN---" Then
            Occurrence.BOMStructure = kPhantomBOMStructure
        End If
    Next
End Sub
you can adapt it to your needs.
You are the best!
Thank you so much. I tried it and it works like a charm!
