TABLE COLUM HEADER JUSTIFICATION
Hi, im trying to bottom justify the text in the column header but i just can´t, i already made the proper layout in the Style Editor
bradeneuropeArthur
Think this is not supported via the API!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
I have tested:
And this seems to be not supported.
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim c As Sheet
Set c = b.Sheets.Item(1)
Dim pl As PartsList
Set pl = c.PartsLists.Item(1)
Dim plc As PartsListColumn
Set plc = pl.PartsListColumns.Item(1)
plc.TitleHorizontalJustification = kAlignTextLeft
'plc.TitleVerticaljustification ....... This is not supported
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
