syntax help needed - value found -value not found
tracey
tracey
Hi, I wonder if anyone can help me.   This code defaults to value found.
If foundVal = MultiValue.FindValue(MultiValue.List("DoorLowerC"), "=", Parameter("Door_Lower"))
    MessageBox.Show("Door Lower C Value found", "Value found", MessageBoxButtons.OK)
Else
    foundVal = MultiValue.FindValue(MultiValue.List("DoorLowerC"), "=", " ")
    MessageBox.Show("No value found", "No Match", MessageBoxButtons.OK)
 I am trying to say:  if  a value in list DoorLowerC matches the parameter Door_Lower then msg box, value found but if a matching value cannot be found, then msg box, not found.
Please help if you can
Many thanks
bradeneuropeArthur
You need to add the "unit" string (mm deg ul etc..)
If foundVal = MultiValue.FindValue(MultiValue.List("DoorLowerC"), "=", Parameter("Door_Lower")&"mm")
Else
    foundVal = MultiValue.FindValue(MultiValue.List("DoorLowerC"), "=", "" )
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
your search string should be exactly like in the multi-value list.
like:
1mm
or
1 mm
or
1deg
or
1 deg
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
tracey
Thank you for your help.  Very appreciated.  Actually, I think I have this wrong by putting text at the end.  It doesn't stop the rule running though and my problem is that both text boxes show ' as found' when only A should give this result.
Any ideas on what I am doing wrong?
I have posted the code here:
MultiValue.SetValueOptions(True, DefaultIndex := 0)
Dim Door_Lower As String
'current value KK
Dim Door_Upper As String
'current value L
MultiValue.SetList("Door", "DoorA_E6Both","DoorB_E2E4Both","DoorC_E6Lower","DoorD_E6Upper")
MultiValue.SetList("DoorA_E6Both",  "AA", "BB", "CC", "DD", "EE", "FF", "GG", "HH", "II", "JJ", "KK", "LL", "MM", "NN", "OO", "PP", "QQ")
MultiValue.SetList("DoorB_E2E4Both",  "GG", "HH", "MM", "NN", "G", "H", "M", "N")
MultiValue.SetList("DoorC_E6Lower",  "A", "B", "C", "D", "E", "F", "G", "H", "I", "J", "K", "L", "M", "N", "O", "P")
MultiValue.SetList("DoorD_E6Upper",  "A", "B", "C", "D", "E", "F", "I", "J", "K", "L", "O", "P", "GG", "HH", "MM", "NN")
 If foundVal = MultiValue.FindValue(MultiValue.List("DoorA_E6Both"), "=", Parameter("Door_Lower")&"Text") Then
    MessageBox.Show("Door Lower A Value found", "Value found", MessageBoxButtons.OK)
Else
    foundVal = MultiValue.FindValue(MultiValue.List("DoorLowerC"), "<>",Parameter("Door_Lower")&"Text")
If foundVal = MultiValue.FindValue(MultiValue.List("DoorC_E6Lower"), "=", Parameter("Door_Lower")&"Text") Then
Else
dusan.naus.trz
I would also like to know where the mistake is. I think the functionality doesn't support text.
JelteDeJong
It works for strings. There is another problem here. The variable "foundVal"(1) is "Nothing" because it was never set. The function "MultiValue.FindValue()"(2) will return "Nothing" or the found value. So if the value is not found it will return Nothing and that is compared with the other Nothing. So that evaluates to True. On the other hand, if the value is found it returns the value and that is compared with the Nothing. That evaluates to False.
Jelte de Jong
Blog: hjalte.nl - github.com
dusan.naus.trz
