Switching beween Edit Member Scope & Factory Scope programatically via VBA
3DAli
3DAli
Hi everyone,
I am trying to cycle through all referenced documents in an assembly and toggle between edit member scope and factory scope, the code works if there is no model state other than the default primary, but if any of the referenced documents has an existing modelstate , regardless of it being active or not, the code fails at the method :
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    ' Get all of the referenced documents.
    Dim oRefDocs As DocumentsEnumerator
    Set oRefDocs = oAsmDoc.AllReferencedDocuments
    Dim oPartDoc As PartDocument
    Dim oPartCompDef As PartComponentDefinition
    Dim oAssDoc As AssemblyDocument
    Dim oAssCompDef As AssemblyComponentDefinition
    If CommandButton1.Caption = "Set All to Edit Member Scope" Then
        CommandButton1.Caption = "Set All to Edit Factory Scope"
        Mode = "MS"
    Else
        Mode = "FS"
    End If
    ' Iterate through the list of documents.
    Dim oRefDoc As Document
    For Each oRefDoc In oRefDocs
        Debug.Print oRefDoc.DisplayName
        If oRefDoc.DocumentType = kPartDocumentObject Then
          Set oPartDoc = oRefDoc
          Set oPartCompDef = oPartDoc.ComponentDefinition
          If Mode = "MS" Then
                Debug.Print oPartCompDef.ModelStates.ActiveModelState.Name
                oPartCompDef.ModelStates.MemberEditScope = kEditActiveMember
          Else
                oPartCompDef.ModelStates.MemberEditScope = kEditAllMembers
          End If
        End If
        If oRefDoc.DocumentType = kAssemblyDocumentObject Then
          Set oAssDoc = oRefDoc
          Set oAssCompDef = oAssDoc.ComponentDefinition
          If Mode = "MS" Then
             oAssCompDef.ModelStates.MemberEditScope = kEditActiveMember
          Else
                oAssCompDef.ModelStates.MemberEditScope = kEditAllMembers
          End If
        End If
    Next
any idea of what might be the cause, I have also tried to use a factory document where the referenced document has more than one model state, and that doesn't even support setting the model states to "all members" or "member only", so any clue as to how might can this be approached would be greatly appreciated.
Best
Ali
JelteDeJong
have a look at this iLogic code. I expect that it does what you want.
Sub Main()
	Dim doc As AssemblyDocument = ThisDoc.Document
	SetMemberEditScope(doc)
End Sub
Public Sub SetMemberEditScope(doc As Document)
	If (doc.ComponentDefinition.IsModelStateMember) Then
		doc = doc.ComponentDefinition.FactoryDocument
	End If
	Dim modelstates = doc.ComponentDefinition.ModelStates
	modelstates.MemberEditScope = MemberEditScopeEnum.kEditAllMembers
	If (doc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject) Then
		For Each occ As ComponentOccurrence In doc.ComponentDefinition.Occurrences
			SetMemberEditScope(occ.Definition.Document)
		Next
	End If
End Sub
You might also consider moving away from VBa, and stop developing in VBa, it's obsolete.
Jelte de Jong
Blog: hjalte.nl - github.com
Frederick_Law
There was a post last week.
MemberEditScrope is not available until 2024.
Before that, need to add Windows Environment Variable to turn it on.
Here: https://forums.autodesk.com/t5/inventor-programming-ilogic/update-parameter-using-ilogic-in-all-mode...
