Copy rules all at once
npokhrelYK39M
npokhrelYK39M
hi, seems like I cant copy all the rules from one assembly files to another all at once? Do I have to do it one by one?
bradeneuropeArthur
with this method:
Dim oDoc As Inventor.Document = ThisApplication.ActiveDocument
Dim oRuleName As String = "RuleName"
Dim oAuto As IiLogicAutomation = iLogicVb.Automation
Dim oRule As iLogicRule
Try
        oRule = oAuto.GetRule("your file name here",oRuleName)
Catch
        MsgBox("The specified rule was not found in the active document. Exiting.",vbOKOnly," ")
        Exit Sub
End Try
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
WCrihfield
Yes.  It has to be done one at a time, either manually, or by code.
Wesley Crihfield
(Not an Autodesk Employee)
