switch between flush and mate
Is there a way to switch between flush and mate using macro?
thx
From a quick look at the API docs, it looks like you would have to use
the info from the flush constraint to add a new mate contraint and then
delete the flush constraint, as far as I can see. I bet the UI does it the same
way.
Bob S.
"Chris" wrote in message news:[email protected]...
thx
As I remember that is what I do in KWiKSert
Autodesk Discussion Group Facilitator
http://discussion.autodesk.com/
"Bob S." wrote in message
same
way.
Bob S.
thx
Hi kent,
Can you post the code?
Thx
"Kent Keller" wrote in message
same
way.
Bob S.
thx
I took a quick look back at the code and it is a little to spread out to
post anything that would be helpful.
Basically in mine, I set up the transaction manager before making the
constraint, and then if the person clicks the flush button I undo the
transaction, and then re-run the constraint code which checks the state of
the buttons before making the constraint.
Kent Keller
Autodesk Discussion Forum Facilitator
Hi kent,
Thx
Curtis_Waguespack
