VBA -> .Net Problem with Point2D
Martin-Winkler-Consulting
Advisor Advisor
i am actually writing VBA Code to VB.Net and have a problem with a Point2D object.
The macro shall align text, views and titles in an idw using the first selected object.
In VBA the macro works fine. In VB.NET i get a failure with the COM Object.
Any idea?
This is the example in VBA for the X Axis:
Sub AlignX()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSelect As SelectSet
Set oSelect = oDoc.SelectSet
Dim newPoint As Point2d
Set newPoint = oSelect.Item(1).Position
For Each obj In oSelect
  newPoint.Y = obj.Position.Y
  obj.Position = newPoint
Next
End Sub
VB.Net Code:
Sub AlignX()
            Dim oDoc As DrawingDocument = InventorApp.ActiveDocument
            Dim oSelect As SelectSet = oDoc.SelectSet
            Dim tg As TransientGeometry = InventorApp.TransientGeometry
            Dim newPointX As Point2d = Nothing
            Dim obj As Object
            newPointX = tg.CreatePoint2d(oSelect.Item(1).Position.X, oSelect.Item(1).Position.Y)
                    obj.Position = newPointX
                Next
            End Sub
In the  For Each loop at obj.Position = newPointX  .Net creates the failure.
Best Regards Martin
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
YuhanZhang
Can you provide the document(if it is not confidential) and create a snapshot to tell which objects are selected, and we can look into where the problem is?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
for better understanding the tool i make a video in which you can see how the tool works with the VBA Code.
You can try it in every idw!
After several workarrounds i think the problem is with the selected obj. because obj is declared as Object.
This is neccessary because obj can become different object types. But all of this objects have an obj.Position which i can set in VBA without problems.
In .Net there is a Type conflict because .Net not recognized that obj.Position is a Point2D. It.s a System_Com object
I tried declaring obj AS DrawingView...then it works, but only for DrawingViews.
How can i solve this type problem?
Let me know if you need more information.
Best Regards Martin
Martin Winkler
CAD Developer
YuhanZhang
You can change the line
to
CallByName(obj, "Position", vbLet, newPoint)
Hope this helps.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Hi, thanks...thats what i am looking for. Now it works fine.
Best Regards Martin
Martin Winkler
CAD Developer
