iLogic to Format Parts List to Use Stacked Fractions
allimanz
allimanz
Our department has come to the conclusion that stacked fractions is easier for our shop to read. We have changed dimensions and everything we can to show this way. However, the styles editor will not let us default the stock number to show as stacked fractions. See the images below to compare. The first image is when I edit the parts list, the second is when I edit the styles. Unfortunately without the check box, we cannot have the parts list default to stacked fractions since our stock number contains both numbers and letters.
My question is, can ilogic be used to format the parts list as such? If so would someone be so kind as to write something up quickly? With my little knowledge of ilogic it seems like it would be a fairly simple code, but I have never done formatting in ilogic before.
Any help would be much appreciated.
Thank you.
Have you found a solution? I have the same issue.
Thanks.
allimanz
No, we never had any luck with a solution. The shop just has to deal with the formatting.
