Supress with iLogic with If funktion
Message 1 of 20
Hello i made this rule ti surpress my parts (see the picture):
I made this code but it doesent work when i edit my parameters from excel:
If Parameter("Mittelpfosten_vorhanden")=0 Then
Component.IsActive("Mittelpfosten:1") = False
Component.IsActive("Mittelpfosten:2") = False
Component.IsActive("Mittelpfosten:3") = False
End If
If Parameter("Mittelpfosten_vorhanden")=1 Then
Component.IsActive("Mittelpfosten:1") = True
End If
If Parameter("Mittelpfosten_vorhanden")=2 Then
Component.IsActive("Mittelpfosten:2") = True
End If
If Parameter("Mittelpfosten_vorhanden")=3 Then
End If
Can you help me?
Replies (19)
Message 2 of 20
CCarreiras
ElseIf
ElseIf
ElseIf
End If
CCarreiras
Message 3 of 20
rossano_praderi
This is faster, much more easy to read and to implement.
Select Case Parameter("Mittelpfosten_vorhanden")
	Case 0
	Case 1
	Case 2
	Case 3
End Select
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Message 4 of 20
Hello Rossano and than you for the replay
i just tired to insert the rule but i doesent work. it doesen have effect when i change my parameters.
i renamed my LOD to iLogic
Message 5 of 20
CCarreiras
Both Rules are correct.
Maybe it's missing update...
place this below the rule:
SyntaxEditor Code Snippet
InventorVb.DocumentUpdate()
iLogicVb.UpdateWhenDone = True
If this doesnt work,
Post here the files and we will try it.
CCarreiras
Message 6 of 20
https://mega.nz/#!rxVliJja!fpYjph5-3bKBy1hQYGfUWiGmIMhI2zslqFxaBqwK8no
Here have you my files.
FGL assembly is with a excel FGL linked. You can make a model with 1 2 oder 3 Mittepfosten
Message 7 of 20
So i make it wokr (realy i dont knpw how)
Nut still, it doesent work riely fine. My case 3 doesent update when i change my parameter to 3.
Component.IsActive("Komponentenanordnung 4:1") = False
Component.IsActive("Komponentenanordnung 5:1") = False
Component.IsActive("Komponentenanordnung 6:1") = False
Component.IsActive("Untere Lamelle_2:1") = False
Component.IsActive("Obere Lamelle_2:1") = False
Component.IsActive("Obere Lamelle_4:1") = False
Component.IsActive("Obere Lamelle_3:1") = False
Component.IsActive("Obere Lamelle_5:1") = False
Component.IsActive("Untere Lamelle_5:1") = False
End If
i miss: Mittelpfosten 3, Obere Lamelle_5,Untere_Lamellen_5 and Komponentenanordnung 6.
But i cant find a error in my rule
Message 8 of 20
CCarreiras
I will look better in your assembly next week.
They are missing files... have you made a "pack and go" to copy the assembly files and linked files.
Also.... im seing that you doesnt use a project file (*.ipj) for this iLogic assembly. It will work much better if you create a ipj to manage all links between files and folders, etc.... read about project files and create one.
CCarreiras
Message 9 of 20
Thank yoou.
shuld i send you the file again?
How can i create a project file? just save it in my folder?
Message 10 of 20
Hello CarlossC
I have make a project file in my folder like here:
But still id doesent work. Whant can i do to make the case 3 active?
Thanks!
Aleksandar
Message 11 of 20
CCarreiras
Hi!
I can't do much to help you... simply i can't test...
It's missing parts and there's some errors in the assembly (maybe due these missing files).
You have to save your assembly as "Pack and go" and post here.
If you place here the complete assembly, will be glad to help.
CCarreiras
Message 12 of 20
Hi CarlossC
Here you have the link for downloading the file (in folder Workgrups, NotInProject):
https://mega.nz/#!q98j1YTR!L3xHlWNCzJHdKnBc8JSyZO4WOR_q-HRAjlctUbSAu_U
I use the option pack and go.
Message 13 of 20
CCarreiras
Select Case Mittelpfosten_vorhanden
    Case 0
    Case 1
    Case 2
    Case 3
        Component.IsActive("Mittelpfosten:3") = True
End Select
CCarreiras
Message 14 of 20
CCarreiras
I think the problem isn't the  rule, but in the parameter.
If you change the parameter, the rule works well.
CCarreiras
Message 15 of 20
Good thank you i will use your rule to supress my parts. Thank you for the video.
But how can i mak a user parameter and edit it from excel?
Shold i make a new user parameter, to linked it in my rule?
Message 16 of 20
Here is it now. It works for case 2 3 4 but in case 1 he doesent supress:
Select Case Probe_2
Case 2
Component.IsActive("Mittelpfosten:1") = 0
Component.IsActive("Mittelpfosten:2") = 0
Component.IsActive("Mittelpfosten:3") = 0
Component.IsActive("Komponentenanordnung 4:1") = 0
Component.IsActive("Komponentenanordnung 5:1") = 0
Component.IsActive("Komponentenanordnung 6:1") = 0
Component.IsActive("Untere Lamelle_2:1") = 0
Component.IsActive("Obere Lamelle_2:1") = 0
Component.IsActive("Obere Lamelle_4:1") = 0
Component.IsActive("Obere Lamelle_3:1") = 0
Component.IsActive("Obere Lamelle_5:1") = 0
Component.IsActive("Untere Lamelle_5:1") = 0
Probe_2 is a new user parameter that i linked with my excel (case 2 is the frist case, when the Mitelpfosten supress is)
I dont know why he doesent supress, but all components are "Falase"
Message 17 of 20
CCarreiras
  • In the assembly you sent is  missing the part i told you before, again. I guess is doing some rule that is calling that unisistent part.
  • This rule you're speaking now... i can't find it... i can't test it
  • All that "side" rules: convert to pdf, email stuff, etc etc.... you must have to do this after you have a stable cad model (your model will start to be a mess, and you will loose tracking what is goin wrong and why). """You started the configuration starting the house from the roof"""
I think your main problems are in the excel parameters, some wrong links, because the rules work if you change the parameter mannually.
Have you try changing the parameters in a form, instead using excel?
CCarreiras
Message 18 of 20
hello aganin Carloss
Yes i tried iand i bekomme this yellow fields:
Do yoi know what that means?
Message 19 of 20
CCarreiras
NO i don't know what it is... but can't be a good thing 🙂
Post the files....
CCarreiras
Message 20 of 20
My mega clodu doesent work yet.
Can you send me a prvivate e mail please?
