Help with Supress component with iLogic
Hello
i made this rule for supressing my components but it doesen work:
If param_val = Parameter("Mittelpfosten_vorhanden")=0 Then
Component.IsActive("Mittelpfosten:1") = 0
If param_val = Parameter("Mittelpfosten_vorhanden")=1 Then
Component.IsActive("Mittelpfosten:1") = 1
Can you help me?
VdVeek
Do you get an error when you run a rule with this line?
Which Level of Detail is active when you rune your rule? If it's the Master or a locked one, it's not possible to suppres a part.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
Hello Rob
Sometimes it woeks when i edit my parameters somerimes no.
CCarreiras
Hi!
Change the LOD name. Call it iLogic.
CCarreiras
CCarreiras
Try this:
If param_val =0 Then
ElseIf
param_val = 1 Then
CCarreiras
Hallo CarlosC
I use the code:
If param_val =0
Shuold I not If param_val ("Parameter") =0 writte?
and how did renaming to "iLogic" had a effect on my assembly?
