Suppress all library components (VB)
shrey9GP3F
shrey9GP3F
I want to create a code that will suppress all the library components. The following code is not working.
Please help!
Sub Main
	On Error Resume Next
	If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then MessageBox.Show("This rule is designed to only work in assembly documents.", "Wrong Document Type") : Exit Sub
	Dim parentDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Call AssemblyRunner(parentDoc)
End Sub
Sub AssemblyRunner(aDoc As AssemblyDocument)
	If aDoc.ComponentDefinition.Object.Type = "50447872" Then
		Call CCRunner(aDoc.ComponentDefinition.Object)
	Else
		For Each oOcc As ComponentOccurrence In aDoc.ComponentDefinition.Occurrences
			If oOcc.DefinitionDocumentType = kAssemblyDocumentObject
				Call AssemblyRunner(oOcc.Definition.Document)
			Else If oOcc.DefinitionDocumentType = kPartDocumentObject
				If oOcc.Object.Type = "50447872" Then
					Call CCRunner(oOcc.Definition.Document)
				Else
					Return
				End If
			End If
	Next
	End If
End Sub
Sub CCRunner(pDoc As PartDocument)
	Component.IsActive(pDoc) = False
End Sub
JelteDeJong
I'm not entirely sure what you mean by: "library components". Are these the content centre parts or the files you put in the library folder that you defined in your project file? Any way this code can check both cases. In the code, I commented on how to activate them. (Disclaimer I have no "library components" here on my test pc so I did not test this myself....)
Also, I used some functions that I explained in more detail in my blog post "Universal occurrence search function".
Sub Main()
    Dim doc As AssemblyDocument = ThisDoc.Document
    Dim list As IEnumerable(Of ComponentOccurrence)
    list = findAllWhere(doc, AddressOf IsContentMember)
    ' uncomment next line if you want  to search by foldername
    'list = findAllWhere(doc, AddressOf IsInLibaryFolder)
    For Each occ As ComponentOccurrence In list
        occ.Suppress()
    Next
End Sub
Public Function IsInLibaryFolder(occ As ComponentOccurrence) As Boolean
    Try
        ' Change this to your library folder
        Dim libraryFolderName As String = "C:\Users\Public\Documents\Autodesk\Inventor Electrical Library 2020"
        Return occ.ReferencedFileDescriptor.FullFileName.Contains(libraryFolderName)
    Catch ex As Exception
        MsgBox("Could not check 'IsInLibaryFolder' for occurence " & occ._DisplayName)
        Return False
    End Try
End Function
Public Function IsContentMember(occ As ComponentOccurrence) As Boolean
    Try
        Dim def As ComponentDefinition = occ.Definition
        Dim doc As Document = def.Document
        If doc.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then Return False
        Dim pDoc As PartDocument = doc
        Return pDoc.ComponentDefinition.IsContentMember
        MsgBox("Could not check 'IsContentMember' for occurence " & occ._DisplayName)
        Return False
    End Try
End Function
Public Function findAllWhere(doc As AssemblyDocument,
            predicate As Func(Of ComponentOccurrence, Boolean)) As IEnumerable(Of ComponentOccurrence)
    Dim list As IEnumerable(Of ComponentOccurrence) = doc.ComponentDefinition.
        Occurrences.Cast(Of ComponentOccurrence).
        Where(predicate)
    Dim assemblyList As IEnumerable(Of ComponentOccurrence) = doc.ComponentDefinition.
        Where(Function(o) o.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject)
    For Each assOcc As ComponentOccurrence In assemblyList
        If TypeOf assOcc.Definition Is VirtualComponentDefinition Then Continue For
        Dim assDoc As AssemblyDocument = assOcc.ReferencedDocumentDescriptor.ReferencedDocument
        Dim listToAdd As IEnumerable(Of ComponentOccurrence) = findAllWhere(assDoc, predicate)
        list = list.Concat(listToAdd)
    Next
    Return list
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
shrey9GP3F
Thank you for your reply. I tried running your code. It throws this error. I want to suppress all components that are in
or in
JelteDeJong
I don't know what the message is about. But I changed the code for your exact situation. I also tried to test it and I did not run into problems.
Sub Main()
        occ.Suppress()
    Next
End Sub
    Try
        Dim libraryFolderName1 As String = "C:\Users\Public\Documents\Autodesk\Inventor Electrical Library 2020"
		Dim libraryFolderName2 As String = "C:\Users\Public\Documents\Autodesk\Inventor Electrical Library 2020"
        Return (occ.ReferencedFileDescriptor.FullFileName.Contains(libraryFolderName1) Or
		       occ.ReferencedFileDescriptor.FullFileName.Contains(libraryFolderName2))
        Return False
    End Try
End Function
        Where(predicate)
    Next
    Return list
End Function
Jelte de Jong
shrey9GP3F
Thank you so much.
