Where to find variants in the API?
aelqabbany
aelqabbany
When an Inventor API method lists a variant as an argument, where can I go to see my different options?
Usually I can click on the object/enum name and I am sent to a page that shows me my different options.
Here are two examples:
https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-1CDF9F9D-A4E5-4961-B518-D7166F6A082E
 https://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-5BFD1ED3-6003-491C-A197-22624521E960
Michael.Navara
VBA documentation says:
The Variant data type is the data type for all variables that are not explicitly declared as some other type (using statements such as Dim, Private, Public, or Static).
See the link below for more info
https://docs.microsoft.com/en-us/office/vba/language/reference/user-interface-help/variant-data-type
In your cases the scale can be string (for example: "1:5") or double ( 0.2 ).
In the second case the possible values are described in description column. Possible types can be PointIntentEnumPoint2d or double
WCrihfield
That 'Variant' Type is still available for use within VBA, but has been discontinued within VB.NET (which is what iLogic uses), in favor of the 'Object' Type.  So, basically anywhere you see it requesting a variable of 'Variant' Type, just substitute 'Object' Type in its place, when working in iLogic or VB.NET.
https://docs.microsoft.com/en-us/dotnet/visual-basic/misc/bc30804
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
