Submenu in linear marking menu
jan.pomplun
Message 1 of 12
jan.pomplun
I want to extend the linear context menu by a sub menu as shown here ("Messen"):
I know how to add usual buttons via:
public void UserInputEvents_OnLinearMarkingMenu_Handler(ObjectsEnumerator selectedEntities, SelectionDeviceEnum selectionDevice, CommandControls linearMenu, NameValueMap additionalInfo)
    linearMenu.AddButton(...);
but can not find any example/documentation, how to add a sub menu.
Jan
Replies (11)
Message 2 of 12
bradeneuropeArthur
CommandControls.AddSplitButton..........
For Example:
Sub AddPanelToToolsTab()
    ' Get the ribbon associated with the part document
    Dim oPartRibbon As Ribbon
    Set oPartRibbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Part")
    ' Get the "Tools" tab
    Dim oTab As RibbonTab
    Set oTab = oPartRibbon.RibbonTabs.Item("id_TabTools")
    ' Create a panel named "Update", positioned after the "Measure" panel in the Tools tab.
    Dim oPanel As RibbonPanel
    Set oPanel = oTab.RibbonPanels.Add("Update", "ToolsTabUpdatePanel", "SampleClientId", "id_PanelP_ToolsMeasure")
    ' Get the update commands
    Dim oDef1 As ButtonDefinition
    Set oDef1 = ThisApplication.CommandManager.ControlDefinitions.Item("AppLocalUpdateCmd")
    Dim oDef2 As ButtonDefinition
    Set oDef2 = ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd")
    Dim oDefs As ObjectCollection
    Set oDefs = ThisApplication.TransientObjects.CreateObjectCollection
    oDefs.Add oDef1
    oDefs.Add oDef2
    ' Create a split button control
    Call oPanel.CommandControls.AddSplitButton(oDef1, oDefs, True)
    ' Get the rebuild command
    Dim oDef3 As ButtonDefinition
    Set oDef3 = ThisApplication.CommandManager.ControlDefinitions.Item("AppRebuildAllWrapperCmd")
    ' Create a button control
    Call oPanel.CommandControls.AddButton(oDef3, True)
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 12
jan.pomplun
I am having issues with the examples I find.
Adding the Split Button to ribbons control works:
                    ButtonDefinition button = (ButtonDefinition)InventorUtil.InventorApplication.CommandManager.ControlDefinitions["AppLocalUpdateCmd"];
                    ObjectCollection subDefTest = InventorUtil.InventorApplication.TransientObjects.CreateObjectCollection();
                    subDefTest.Add(button);
                    blockManagementRibbonPanelCtrls.AddSplitButton(button, subDefTest);
the same code however fails on the linear menu:
                            ButtonDefinition button =(ButtonDefinition) InventorUtil.InventorApplication.CommandManager.ControlDefinitions["AppLocalUpdateCmd"];
                            linearMenu.AddSplitButton(button, subDefTest);
an exception is thrown:
System.Runtime.InteropServices.COMException: "Unbekannter Fehler (Ausnahme von HRESULT: 0x80004005 (E_FAIL))"
Do split buttons work in the context menu?
Thanks and best,
Jan
Message 4 of 12
dgreatice
hi,
try find some information from:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-20E1627B-F1B6-45A4-A1EB-A28750F761FB
I think marking menu not use ButtonDefinition, but use ControlDefinitions
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 5 of 12
dgreatice
for Commandcontrols.AddSplitButton or AddSplitButtonMRU object must be ControlDefinition, not Buttondefinition.
Message 6 of 12
bradeneuropeArthur
 Private Sub oUserInputEvents_OnContextMenu(SelectionDevice As Inventor.SelectionDeviceEnum, AdditionalInfo As Inventor.NameValueMap, CommandBar As Inventor.CommandBar) Handles oUserInputEvents.OnContextMenu
For Each control As CommandBarControl In CommandBar.Controls
 Try
            ' Check if the context menu has the 'Home View' (formerly 'Isometric View') command
            Dim oCmdBarControl As CommandBarControl
            oCmdBarControl = CommandBar.Controls.Item("AppIsometricViewCmd")
            Dim ControlsCounter As Integer
            ControlsCounter = CommandBar.Controls.Count
            If Not oCmdBarControl Is Nothing Then
                ' add the buttonCommand to the end
                Call oCommandBar.Controls.AddsplitButton(!!!!!!!!!)
        Catch ex As Exception
        End Try
next
end sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 12
jan.pomplun
the link points to
RadialMarkingMenu Objects
help. This is not what I am trying to do.
The split button is intended to be added to the linear menu not the radial
mEventsObj.OnLinearMarkingMenu += UserInputEvents_OnLinearMarkingMenu_Handler;
Message 8 of 12
jan.pomplun
After some research it seems to be an old problem:
Buttons (other than ordinary) can not be added to the context menu:
https://forums.autodesk.com/t5/inventor-customization/how-to-add-a-amp-quot-popupbutton-amp-quot-in/...
as so often the problem has been reported ages ago, and is still not fixed 😞
Does autodesk have the intention to fix it?
Message 9 of 12
bradeneuropeArthur
of course it is possible:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 12
jan.pomplun
the picture is cropped, I can not see where this is a SUB menu.
Can you post the code?
I know that inventor has submenus, as the picture of my original post shows, but I get an exception thrown when I add the split button to the context menu.
The same code works adding the split button to the ribbon, so I do not see what I am doing wrong.
Thakns and best,
Jan
Message 11 of 12
bradeneuropeArthur
ok.
i will try..........
the buttons are added to the RMB menu Context menu.
I will try to add a submenu.
Will come back to it ASAP....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 12
c_hoppen
He never came back 😉
Is there a solution for this in the meantime?
