STUCK ON ERROR IN VISUAL STUDIO
jpchaisson
jpchaisson
is there anyone that knows how to fix this error....
Could you post the whole code? It looks like you probably just defined something wrong
jpchaisson
Imports System
Imports System.IO
Imports System.Drawing
Imports System.Data
Imports System.Collections
Imports System.Windows.Forms
Imports System.Drawing.Printing
Imports Microsoft.VisualBasic
Imports Inventor
Public Class Form1
    Public oApp As Inventor.Application = GetObject(, "Inventor.Application")
    Public oSketch As PlanarSketch
    Public InletHoleDia As Double
    Public oCompDef As PartComponentDefinition
    Public oUOM As UnitsOfMeasure
    Public SketchNumber As Integer
    Public WorkPlaneNumber As Integer
    Public r As String
    Public f As String
    Private Sub Button_SaveTo_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button_SaveTo.Click
        Dim FileSearchDialog As New OpenFileDialog()
        Dim SelectedFile As String
        Dim FilePath As String
        FileSearchDialog.InitialDirectory = "C:\My Documents"
        FileSearchDialog.Filter = "Text files (*.txt)|*.txt|All files (*.*)|*.*"
        If FileSearchDialog.ShowDialog() = DialogResult.OK Then
            SelectedFile = FileSearchDialog.FileName
            FilePath = IO.Path.GetFullPath(SelectedFile)
            TB_SaveTo.Text = FilePath
        End If
    End Sub
    Private Sub Button_InData_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button_InData.Click
            TB_InData.Text = FilePath
        End If
    End Sub
    Private Sub Button_OutData_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button_OutData.Click
            TB_OutData.Text = FilePath
        End If
    End Sub
    Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button_Create.Click
        Dim oPartDoc As PartDocument
        Dim oOriginSketchPoint As SketchPoint
        Dim PipeOD, PipeWT, PipeLen As Double
        Dim oCircle(0 To 2) As SketchCircle
        Dim i As Integer
        Dim oPoint As SketchPoint
        Dim oTG As TransientGeometry
        Dim oDims(0 To 10) As DimensionConstraint
        Dim oProfile As Profile
        Dim oExtrude As ExtrudeFeature
        '********** CREATE NEW PART (PIPE, REFERENCE THE COMPONENT AND CREATE SKETCH ON "XY" WORK PLANE THEN PROJECT SKETCH ORIGIN *
        oPartDoc = oApp.Documents.Add(DocumentTypeEnum.kPartDocumentObject, _
                                    oApp.FileManager.GetTemplateFile(DocumentTypeEnum.kPartDocumentObject))
        oCompDef = oPartDoc.ComponentDefinition
        oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes.Item(3))
        oOriginSketchPoint = oSketch.AddByProjectingEntity(oCompDef.WorkPoints.Item(1))
        '********** CONVERT FORM TEXTBOXES TO DOCUMENT UNITS *********************************************************************************
        oUOM = oApp.ActiveDocument.UnitsOfMeasure
        'TEXTBOX "TB_Dia"
        PipeOD = oUOM.GetValueFromExpression(Val(TB_Dia.Text), UnitsTypeEnum.kDefaultDisplayLengthUnits)
        'TEXTBOX "TB_WT"
        PipeWT = oUOM.GetValueFromExpression(Val(TB_WT.Text), UnitsTypeEnum.kDefaultDisplayLengthUnits)
        'TEXTBOX "TB_length"
        PipeLen = oUOM.GetValueFromExpression(Val(TB_Length.Text), UnitsTypeEnum.kDefaultDisplayLengthUnits)
        '********** DRAW HOR/VER SKETCH LINES AND ACRS ***************************************************************************************
        'PIPE PROFILE.
        oTG = oApp.TransientGeometry
        oPoint = oSketch.SketchPoints.Add(oTG.CreatePoint2d(0, 0), False)
        oCircle(1) = oSketch.SketchCircles.AddByCenterRadius( _
            oPoint, Val(PipeOD) / 2)
        oCircle(2) = oSketch.SketchCircles.AddByCenterRadius( _
            oPoint, Val(PipeOD - (PipeWT * 2)) / 2)
        '********** DIMENSION SKETCH CIRCLE ***************************************************************************************************
        'PIPE PROFILE.
        oDims(1) = oSketch.DimensionConstraints.AddDiameter( _
            oCircle(1), oTG.CreatePoint2d(1, 1), False)
        i = oSketch.DimensionConstraints.Count
        oSketch.DimensionConstraints.Item(i).Parameter.Value = PipeOD
        oDims(2) = oSketch.DimensionConstraints.AddDiameter( _
            oCircle(2), oTG.CreatePoint2d(-1, -1), False)
        oSketch.DimensionConstraints.Item(i).Parameter.Value = (PipeOD - (PipeWT * 2))
        '********** CONSTRAIN SKETCH CIRCLE **************************************************************************************************
        With oSketch.GeometricConstraints
            'LEFT TANGENT LINE.
            .AddCoincident(oCircle(1).CenterSketchPoint, oCircle(2).CenterSketchPoint)
            .AddCoincident(oCircle(1).CenterSketchPoint, oPoint)
            .AddCoincident(oPoint, oOriginSketchPoint)
        End With
        '********** EXTRUDE SKETCH1 ***********************************************************************************************************
        oProfile = oSketch.Profiles.AddForSolid
        oExtrude = oCompDef.Features.ExtrudeFeatures.AddByDistanceExtent( _
            oProfile, Val(PipeLen), PartFeatureExtentDirectionEnum.kSymmetricExtentDirection, _
            PartFeatureOperationEnum.kJoinOperation)
        '********** READ INLET DATA TEXT FILE ***********************************************************************************************************
        Dim FileName As String = TB_InData.Text
        Dim lines() As String = IO.File.ReadAllLines(FileName)
        Dim lineArray As New ArrayList()
        Dim s As String
        Dim substring() As String
        Dim Item As String
        Dim Cnt As Integer
        'Dim LineNumber As Integer
        oApp.ActiveView.GoHome()
        For x As Integer = 0 To lines.GetUpperBound(0)
            lineArray.Add(lines(x))
        Next
        For LineNumber = 0 To lineArray.Count - 2
            s = lineArray.Item(LineNumber)
            substring = s.Split(vbTab)
            'LineNumber = x
            Cnt = 0
            For Each Item In substring
                If Item = "" Then
                ElseIf Item = vbTab Then
                ElseIf Cnt = 0 Then
                    Dim oActiveDoc As PartDocument
                    Dim oPartCompDef As PartComponentDefinition
                    Dim BaseXY As WorkPlane
                    Dim PreviousWorkPlane As WorkPlane
                    Dim CurrentWorkPlane As WorkPlane
                    Dim AxisX As WorkAxis
                    Dim oANG1 As String
                    Dim oNewWorkPlane As WorkPlane
                    Dim oHole(0 To 2) As SketchCircle
                    Dim AddSketch As Sketch
                    Dim OriginPoint As SketchPoint
                    oActiveDoc = oApp.ActiveDocument
                    oPartCompDef = oPartDoc.ComponentDefinition
                    BaseXY = oPartCompDef.WorkPlanes.Item(1)
                    AxisX = oPartCompDef.WorkAxes.Item(3)
                    oANG1 = Item & " grd"
                    If LineNumber = 0 Then
                        oPartCompDef.WorkPlanes.AddByLinePlaneAndAngle(AxisX, BaseXY, oANG1)
                    Else
                        PreviousWorkPlane = oPartCompDef.WorkPlanes.Item(LineNumber + 3)
                        oPartCompDef.WorkPlanes.AddByLinePlaneAndAngle(AxisX, PreviousWorkPlane, oANG1)
                    End If
                        SketchNumber = 2
                        WorkPlaneNumber = 1
                        r = "Work Plane" & WorkPlaneNumber
                        f = "Sketch" & SketchNumber
                        CurrentWorkPlane = oCompDef.WorkPlanes.Item(r)
                        AddSketch = oCompDef.Sketches.Add(CurrentWorkPlane, True)
                        oSketch = oCompDef.Sketches.Item(f)
                    Else
                    End If
                    Cnt = Cnt + 1
                    ElseIf Cnt >= 1 Then
                        Dim InletHoleLocation As Double
                    Dim ItemConvert As Integer
                        Dim oHole(Cnt) As SketchCircle
                        ItemConvert = Item / 25.4
                        InletHoleDia = oUOM.GetValueFromExpression(Val(TB_InletHoleDia.Text), UnitsTypeEnum.kDefaultDisplayLengthUnits)
                        InletHoleLocation = oUOM.GetValueFromExpression(Val(ItemConvert), UnitsTypeEnum.kDefaultDisplayLengthUnits)
                        Dim oCenterPoints As ObjectCollection
                        oCenterPoints = oApp.TransientObjects.CreateObjectCollection
                        oCenterPoints.Add(oSketch.SketchPoints.Add(oApp.TransientGeometry.CreatePoint2d(InletHoleLocation, 0)))
                        oSketch.GeometricConstraints.AddGround(oCenterPoints.Item(1))
                        Cnt = Cnt + 1
                    End If
            Next
            Call Module2.CreateHoleByThroughAllExtent()
            SketchNumber = SketchNumber + 1
            WorkPlaneNumber = WorkPlaneNumber + 1
        Next
    End Sub
    Private Sub Button_Cancel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button_Cancel.Click
        Me.Close()
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Call Module3.AfterFirstWorkPlane()
    End Sub
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
    End Sub
End Class
rjay75
Item is a string so the statement Item / 25.4 is invalid. If Item is the string of a number you can try converting it to a number to use. Or if you know the units the number is in you can pass it to UnitOfMeasure to get the value of it.
Exactly what rjay said. So towards the beginning of that you say:
Dim Item as String
 Which it looks like you need it to be, but you'll want to figure out how to get that string to change to an integer, because later on you say
 It's recognizes your string as characters and your integers as numbers. To do the division, you need them both to be numbers.
