Struggle to rotate occurence in context of assembly
MechMachineMan
Advisor Advisor
MechMachineMan
In order to make laying out large projects, I'm trying to make a program that will allow us to rotate ground parts with respect to an origin axis, but keep their relative position. I have tried using a couple of the matrix operations, but they are not functioning as expected.
As in below, I have created a dummy from vector in the context of the assembly, and then use an angle to set a dummy to vector on the same flat plane. However, every time I run this rule, the transformation instead changes the matrix to align the horizontal planes of both occurrences, whereas I just want the rotation to be as per the given orientation. (Every time I run the rule, it performs 2 rotations, instead of the 1 rotation I am looking for.)
Sub Main()
	Dim oDoc As Document
	oDoc = ThisApplication.ActiveDocument
	Dim oOcc As ComponentOccurrence
	Dim oSelectSet As SelectSet
	oSelectSet = oDoc.SelectSet
	If oSelectSet.Count = 1
		oOcc = oSelectSet.Item(1)
	Else
		MsgBox("Invalid Selection Set!" & vbLf & vbLf & "Aborting rule!")
		Exit Sub
	r = InputBox("Set values of relative rotation of occurence in context of assembly:", "Rotation", "0")
	Call RotateOccurrence(oDoc, oOcc, r, "Y")
End Sub
Sub RotateOccurrence(oAsmDoc As Document, oOcc As ComponentOccurrence, oRotationDeg As Double, oAxis As String)
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Select Case True
		Case oAxis = "X"
			oAsmAxis = oAsmDoc.ComponentDefinition.WorkAxes.Item(1)
		Case oAxis = "Y"
			oAsmAxis = oAsmDoc.ComponentDefinition.WorkAxes.Item(2)
		Case oAxis = "Z"
			oAsmAxis = oAsmDoc.ComponentDefinition.WorkAxes.Item(3)
		Case Else
			MsgBox("Error in fectching Asm Axis")
			Exit Sub
	End Select
	oOcc.CreateGeometryProxy(oOcc.Definition.WorkPoints.Item(1), oCenterPointProxy)
	Dim oOccTransform As Matrix = oOcc.Transformation
	Dim oTransVec As Vector = oOccTransform.Translation
	Dim oFromVector As Vector = oTG.CreateVector(1,0,0)
	Dim oToVector As Vector = oTG.CreateVector(Math.Cos(oRotationDeg*Math.PI/180), 0, Math.Sin(oRotationDeg*Math.PI/180))
	oOccTransform.SetToRotateTo(oFromVector,oToVector, oAsmAxis.Line.Direction.AsVector)
	oOccTransform.SetTranslation(oTransVec, False)
	oOcc.SetTransformWithoutConstraints(oOccTransform)
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
MechMachineMan
After all of the annoyance with trying to use the built in functions, I just went back to the basic math and made something that works;
Sub Main()
	Else
		Exit Sub
	r = InputBox("Set values of relative rotation of occurence in context of assembly:" & vbLf & "X:90 OR other format for reset", "Rotation", "X:0")
	Try
		Dim substring() As String = r.Split(":")
		Call RotateOccurrence(oDoc, oOcc, substring(1), substring(0))
	Catch
		Call RotateOccurrence(oDoc, oOcc, 0, "")
	End Try
End Sub
	Dim oRx As Matrix
	oRx = oTG.CreateMatrix()
	oRx.Cell(2,2) = Math.Cos(oRotationDeg*Math.PI/180)
	oRx.Cell(2,3) = -Math.Sin(oRotationDeg*Math.PI/180)
	oRx.Cell(3,2) = Math.Sin(oRotationDeg*Math.PI/180)
	oRx.Cell(3,3) = Math.Cos(oRotationDeg*Math.PI/180)
	Dim oRy As Matrix
	oRy = oTG.CreateMatrix()
	oRy.Cell(1,1) = Math.Cos(oRotationDeg*Math.PI/180)
	oRy.Cell(1,3) = Math.Sin(oRotationDeg*Math.PI/180)
	oRy.Cell(3,1) = -Math.Sin(oRotationDeg*Math.PI/180)
	oRy.Cell(3,3) = Math.Cos(oRotationDeg*Math.PI/180)
	Dim oRz As Matrix
	oRz = oTG.CreateMatrix()
	oRz.Cell(1,1) = Math.Cos(oRotationDeg*Math.PI/180)
	oRz.Cell(1,2) = -Math.Sin(oRotationDeg*Math.PI/180)
	oRz.Cell(2,1) = Math.Sin(oRotationDeg*Math.PI/180)
	oRz.Cell(2,2) = Math.Cos(oRotationDeg*Math.PI/180)
	Select Case True
		Case oAxis = "X"
			oOccTransform.PreMultiplyBy(oRx)
		Case oAxis = "Y"
			oOccTransform.PreMultiplyBy(oRy)
		Case oAxis = "Z"
			oOccTransform.PreMultiplyBy(oRz)
		Case Else
			MsgBox("Error in rotating matrix; returning to identity")
			oOccTransform.SetToIdentity
	End Select
	PrintMatrix(oOccTransform)
End Sub
Sub PrintMatrix(oMatrix As Matrix)
	For i = 4 To 1 Step -1
		For j = 4 To 1 Step -1
			oStr = oMatrix.Cell(i,j) & "     " & oStr
		Next
		oStr =  vbLf & oStr
	Next
	MsgBox(oStr)
End Sub
Justin K
Very usefull piece of coding;
I have addapted a little but so it will work with my vba.
I also needed to calculate pi myself:
'calculate pi
    pi = Atn(1) * 4
I hope this helps other people as well.
