第 1 条消息(共 6 条)
I'm not exactly sure how to build the string that defines the format of the DXF file.
Here below and example:
Dim sOut As String sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=Outer&InvisibleLayers=IV_Tangent;IV_Bend;IV_Bend_Down;IV_Bend_Up;IV_Arc_Centers"
And here below what is in my *.ini file:
[FP EXPORT SELECT OPTIONS] AUTOCAD VERSION=AutoCAD 2000 USE CUSTOMIZE=No CUSTOMIZE FILE=c:\program files\autodesk\inventor 2013\Design Data\DWG-DXF\FlatPattern.xml [FLATPATTERN LAYER OPTIONS] Tangent Lines=IV_TANGENT:Visibility=OFF;LinePattern=28100;LineWeight=0,0500;Color=0,0,0; Bend Lines (Front)=IV_BEND:Visibility=ON;LinePattern=28100;LineWeight=0,0500;Color=0,255,0; Bend Lines (Back)=IV_BEND_DOWN:Visibility=ON;LinePattern=28100;LineWeight=0,0500;Color=0,0,0; Tool Centers (Front)=IV_TOOL_CENTER:Visibility=OFF;LinePattern=28100;LineWeight=0,0500;Color=0,0,0; Tool Centers (Back)=IV_TOOL_CENTER_DOWN:Visibility=OFF;LinePattern=28100;LineWeight=0,0500;Color=0,0,0; Arc Centers=IV_ARC_CENTERS:Visibility=OFF;LinePattern=28100;LineWeight=0,0500;Color=0,0,0; Outer Profile=IV_OUTER_PROFILE:Visibility=ON;LinePattern=28100;LineWeight=0,0500;Color=0,0,0; Inner Profile=IV_INTERIOR_PROFILES:Visibility=ON;LinePattern=28100;LineWeight=0,0500;Color=0,0,0; Feature Profile (Front)=IV_BEND:Visibility=ON;LinePattern=28100;LineWeight=0,0500;Color=0,255,0; Feature Profile (Back)=IV_FEATURE_PROFILES_DOWN:Visibility=OFF;LinePattern=28100;LineWeight=0,0500;Color=0,0,0; Alternate Rep (Front)=IV_ALTREP_FRONT:Visibility=OFF;LinePattern=28100;LineWeight=0,0500;Color=0,0,0; Alternate Rep (Back)=IV_ALTREP_BACK:Visibility=OFF;LinePattern=28100;LineWeight=0,0500;Color=0,0,0; Unconsumed Sketches=IV_UNCONSUMED_SKETCHES:Visibility=OFF;LinePattern=0;LineWeight=-1,0000;Color=-255,-255,-255; Tangent Roll Lines=IV_ROLL_TANGENT:Visibility=OFF;LinePattern=28100;LineWeight=0,0500;Color=0,0,0; Roll Lines=IV_ROLL:Visibility=OFF;LinePattern=28100;LineWeight=0,0500;Color=0,0,0; [FLATPATTERN GEOMETRY OPTIONS] REBASE GEOMETRY=No GROUP GEOMETRY=Yes REPLACE SPLINE=No SPLINE SIMPLIFICATION METHOD=Linear CHORD_TOLERANCE=0,010
How do I adjust the String (sOut), so all the info above is in there?
Thanks in advance,
Dominiek
已解决! 转到解答。
