Export DXF options
Export DXF options
lrfabs
Message 1 of 10
Export DXF options
lrfabs
Hi All,
I have 2 problems I am trying to overcome:-
  1.  I have realized that it is only possible to have 2 radio buttons available in a section of a rule. The problem is that I would like 3 because I would like a box to appear when outputing dxf's I.E buttons to label "inner profiles" "outer profiles" & "both profiles". This leads me on to Question 2.
  2. How can I set the DXF output options to select the outer profile only ( without any bend lines etc on a sheetmetal part).
Thanks In Advance
Lee
Replies (9)
Message 2 of 10
CCarreiras
Hi!
You can have more then 2 radio buttons, you can have how many you need.
You must have 3 ini files (with dxf defenitions) to each option and 3 the rules to run depending the case you want.
CCarreiras
Message 3 of 10
lrfabs
With that in mind is there a snippet of code that would read this ini file.
Many thanks.
Lee
Message 4 of 10
CCarreiras
Hi!
When you export the flat pattern to dxf, you will have the chance to configure how you wanna have it (inner profiles, outer profiles, et etc). You can save each configuration in one file. This file is your aaaaa.INI file
When you apply one rule to convert a drawing in a dxf, you can make the rule read that ini file to stablish your configuration for the converting.
CCarreiras
Message 5 of 10
lrfabs
Hi ,
Yes I know about the ini configuration but how do i write an ilogic rule to select that ini file.
Many thanks
Lee
Message 6 of 10
I did once some workaround with inputbox. you can type in "1", "2" or "3". if you hit cancel default would be let's say "1".
Or you can do a MsgBox with YesNoCancel. In promp write which button is what. Worked for me.
Message 7 of 10
Hi
I would also like to know how a iLogic rule for dxf output would read the dxf ini file.
I need to get across the flat pattern and include the bend lines (centres only), But these need to be in a different colour (yellow) and line style (chain) to the profile
Message 8 of 10
There are two typer making DXF that I know: from flat pattern and from IDW. IDw can read ini file, flatpattern has input string that determines what is exported. Both will give you bend in yellow. It's easier to define ini file for sure but once you'll create output string it will be aesier to export vie flatpattern.
You can find in the attached pdf (it's printed out from Inventor API help) how to make output string and write iLogic rule.
 edit:
There is also third option to Export DXF. From assembly file. Do you know this solution from exchange appstore? It's free for DXF.
BR
Jozef
Message 9 of 10
lrfabs
Many Thanks.
Just what I needed.
Message 10 of 10
Glad to hear that. Feel free to give kudos 🙂
